iPad Wi Fi Hardly works and at my wits end. Please Help
This is a discussion on iPad Wi Fi Hardly works and at my wits end. Please Help within the iPad Help forums, part of the Apple iPad Discussions category; I have a New Linksys WRT120 Wireless Router. Set up with compatible security settings.
Have reset iPad to factory settings, set it as new.
3 ...
iPad Enthusiast!
3 calls to Apple and Apple store has exchanged it for a new one twice (second time yesterday).
No cordless phones, house is a small two bedroom bungalo with furnished basement. The router is on my desk in the basement.
Even in my room in the basement I only get connection half the time. Upstairs when trying to just sit in front of the tv, chat, surf and so on I have to do a balancing act to try and get connection. Turn left, balance it on the arm of the couch, or turning right and balancing it in my knee and sometimes get a connection, though you look at it the wrong way and it's gone. I can never get a connection just sitting on my lap.
I bought it for going back to school but had a low signal there too, but only tried it once there, 2 bars.
I want to be able to sit in the couch, lay in my bed and connect to the internet when I want without the balancing act or getting frustrated a giving up.
Any help Greatly appreciated. I don't know what else to do, Apple said with a new wireless N router, no cordless phone ect, there shouldn't be a reason for no connection, which is why they replaced it. (3rd iPad same problem) But still same problem and I am really frustrated!
I can't see it being the router, but am wondering if I should replace it. I don't know what else to do.
Thank you
08-12-2010 08:37 PM
Banned
Easy solution, if u have a windows mobile phone, u can just get a wifi tethering app to use. Thats what i do. My phone is tilt2 windows mobile 6.5.1. I use the xda wifi tethering app. My ipad automaticalyy connects everytime with great signal coverage anywhere in my apt. Android phones have tethering apps also. Mines a free app.
Only other thing i can think of is that u need to reconfigure from the router side somehow, or just by one of those wifi signal boosters that go inbetween the router n pc. Ive seen em for sale. My only internet connection is thru my mobile phone. I get great speeds. I already have 6 fulllenght movies n 100 apps downloaded over 3g. Less thn an hr to download 700mb file with adownloader. Pretty decent if i say so to be tethered wirelessly to ky phone.
iPF Super Guru
Well, it could be your router! I know Linksys (Cisco) makes good stuff, but a bad one could have slipped through QC. I have a $20 D-Link 802.11n router that works great with all of my iDevices.
iPad Enthusiast!
Thanks for responding. I have an iPhone though. How would the tethering work, off the 3G? Cause on wi fi the cell and iPad are coming from the same router.
Maybe I will call Linksys and see what they can suggest. Do you think a booster would work, shouldn't the router send enough signal for a small house? (or on the same floor for that matter)
Thanks. I appreciate any input.
Originally Posted by
Demandarin
iPad Enthusiast!
Actually this is the second router the first was faulty so I replaced it for the same one. The first wouldn't set up at all. (I had had it for a little while, but still have the reciept)
I also need a router that is Mac compatible, meaning I can set it up on my desktop Mac.
1991-C4
Banned
You right, ur router should pump out enuff signal strength. Not sure what it could be other thn somethng in the settings of router or router bad. Router gets good signal with other wireless devices? Iphone has some tethering apps out. I beleive u have to jaibreak ur phone first though. Then afterwards just download the wireless tethering app. They even have the app to use ur iphone as a camera for ur ipad. ;-).
iPF Super Guru
CheekyIpad
...shouldn't the router send enough signal for a small house? (or on the same floor for that matter)
I live on 3 acres and my "cheap" router is in the "man cave" in the corner of the house indicated by the red arrow and I have good coverage over my whole property. I listen to streaming audio on my iPod Touch while cutting grass and I have no dropouts anywhere. Sounds like your issue is with your router, not your iPad.
iPad Ninja
Try running some wifi analysis tools on your main machine to test for signal quality and local interference.
I suggest inSSIDer which is free for win machines but don't know a mac equivalent. This will soon tell you if you have router problems.
There have been quite a few threads on these forums regarding wifi connection problems which are worth checking out for suggestions.
Agree with C4 though, the wifi range is excellent on my pad, but that could just be the combination of cheap taiwanese router and it's siteing.
iPad Enthusiast!
What does it mean to jailbreak the iPhone?
Thanks for the info on the app for using the iPhone camera for the iPad. Any idea what it would be called? I looked for it and the tethering app but couldn't find them.
Demandarin
iPad Enthusiast!
Ok I am calling Linksys for sure and taking it back to exchange it. After knowing how much range you get, my situation is even more pathetic.
Can anyone recommend a router? The one I bought cost about $59 (Canadian) so looking to spend the same and needs to be able to connect to my desktop Mac.
1991-C4
CheekyIpad
- You may not post replies
- You may not edit your posts
Forum Rules
By xenon in forum International iPad Users
Last Post: 10-03-2011, 07:24 AM
By jacppe in forum iPad General Discussions
Last Post: 08-16-2010, 01:23 PM
By Timmah in forum iPad Hacking
Last Post: 08-07-2010, 01:09 PM
By mrdinh in forum iPad General Discussions
Last Post: 05-02-2010, 12:39 AM
By iDan in forum Apple iPad News
Last Post: 02-11-2010, 10:38 AM
do they have a wi-fi booster app
free wifi booster download ipad
free wifi booster for ipad
free wifi booster for ipod touch
i am looking for a wi fi booster to boost the signal upstairs. can antone help
ipad apps boost wifi
ipad wifi booster app
linksys wrt120n ipad compatibility
wi fi booster for ipad
wifi booster app for ipad
wifi booster app ipad 2
wrt120 ipad
Tags for this Thread
