Can the IPAD 3 automatically switch between Wifi and Cellular/4G?
This is a discussion on Can the IPAD 3 automatically switch between Wifi and Cellular/4G? within the iPad Help forums, part of the Apple iPad Discussions category; Meaning...is there a setting that will automatically turn off my 4G once I get back home, and default to my WiFi? I keep forgetting to ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By twerppoet
Thread: Can the IPAD 3 automatically switch between Wifi and Cellular/4G?
    230573
    Jul 2012
    New Yawk City
    41
    I keep forgetting to manually switch back to WiFi when I am home and ultimately end up using up a lot of Data.
    1522 times
    Walla Walla, WA
    15,430
    The iPad will always choose a known wi-fi connection over your cellular connection. As long as you've connected to your home wi-fi at least once, the iPad will automatically switch to it when it's detected.
    While the cellular signal strength bar stays, you're connection type indicator (3G, 4G, or LTE) will go away and be replaced by the standard fan shaped wi-fi signal strength indicator.
    Can the IPAD 3 automatically switch between Wifi and Cellular/4G?-cellconnection.jpg
    230573
    Jul 2012
    New Yawk City
    41
    Attachment 21499
    Does keeping the cell signal on have any effect on the battery?
    1522 times
    Walla Walla, WA
    15,430
    Anything has some affect. I haven't noticed and significant extra drain for keeping the cellular radio on.
    However, I've heard that if you keep the cell radio on when there is no service or only a weak signal available it is hard on phone batteries; so that probably applies to iPads as well. The device will expend considerably more power trying to find and connect to a cell tower than it will to maintain that connection.
    13576
    1445 times
    Aug 2010
    Western NY state (USA)
    11,052
    Quote Originally Posted by kwitel View Post
    I just want to add this reminder...
    As far as I can remember, if you have an active 3G account running - when the iPad goes to sleep, it will turn off the WiFi and activate the 3G (unless the iPad is connected to power). This is a battery saving feature.
    There is no way to stop this behavior unless you turn off the 3G or put the iPad into Airplane mode. Or, leave it plugged in when it is sleeping and it will stay connected to the WiFi.
    So, while the iPad will default to the WiFi when it's on, if you are going to leave it sleeping for a while (for example, overnight), I recommend plugging it in. This will prevent the switch to 3G.
    1522 times
    Walla Walla, WA
    15,430
    I'm not sure about the behavior your describing. First I've heard of it. When I have some time I'll see if I can track down the source, unless you happen to find and share it first.
    Of course, when it's in 3G and sleeping it won't automatically download, sync, backup, or do any of the other data intensive tasks. Mostly it just checks for your email and any push notifications.
    289502
    Apr 2013
    This has NOT been my experience with AT&T. And they told me it doesn't switch. Maybe this is a carrier specific feature and AT&T continues to disappoint me. But I'm stuck with them. And more than once my account has been drained and I've closed down all sorts of things. But if I forget to turn off cellular, I'm sunk.
    Attachment 21499
    1522 times
    Walla Walla, WA
    15,430
    If you've previously connected to your home network and can access the internet from it, then the iPad should choose it over the cellular connection. It does not matter who your cellular provider is. It isn't up to them, and they should not be able to change this default behavior.
    If your iPad is not doing this, then something is wrong and it needs to be corrected.
    I could be your home network. If the iPad connects to wi-fi, but can not access the internet for an extended period of time it may switch back to the cellular network. This is especially true if you try browsing or use another app that needs internet access.
    If your home network is reliable, then I'd try to Reset All Settings.
    There was a problem with the early iOS 6.0 updates that affected cellular usage for some people. It was mostly in the U.K., but you should make sure you are updated to iOS 6.1.3 just to be on the safe side.
    Also, bo to be on the safe side, you can go to Settings > Cellular and turn off all the Use Cellular Data for items.
    If you are jailbroken (you would know) all bets are off. You'll have to take that up with the Hacking area.
    The usual fixes:
    Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
    scifan57 likes this.
  1. Wifi only or cellular
    By newtothis in forum New Member Introductions - Site Assistance
    Last Post: 06-25-2012, 07:03 PM
  2. Replies: 1
    Last Post: 03-31-2012, 11:49 PM
  3. Replies: 2
    Last Post: 11-08-2011, 11:15 AM
  4. cellular/ wifi switch
    By ercsliberty in forum iPad General Discussions
    Last Post: 05-19-2011, 06:57 AM
  5. Use ipad side switch for wifi on/off??
    By Kabona in forum iPad Hacking
    Last Post: 04-28-2011, 10:00 AM
does cell connection turn off when wifi is connected on ipad
ipad air cell do they switch to wifi by default
ipad changes from wi fi to lte
ipad switch between wifi and 4g
switch between cell and wi on ipad
switch between cellular wifi ipad
switching from how to go from wifi to 4g on ipad
wifi bar on ipad
