MPEG 4 problems ;-(
This is a discussion on MPEG 4 problems ;-( within the iPad Help forums, part of the Apple iPad Discussions category; Can somebody please help me with this frustrating problem before I go crazy... I have converted some films from AVI to MP4 using Wondershare. I ...
Results 1 to 4 of 4
    230407
    Jul 2012
    Edinburgh
    MPEG 4 problems ;-(
    I have converted some films from AVI to MP4 using Wondershare. I did exactly as I was told: I selected "convert to ipad 3 - MPEG 4 video". When it was done, I dragged it over to iTunes. I went to sync my ipad but when I clicked on the movies icon, only 2 of the 5 films were there. So I tried a different conversion software - "Bigasoft". I did exactly the same thing. Selected the "iPad 3 MPEG 4" from the dropdown menu. When they were finished, I dragged them over to itunes and again, when I went to sync, they did not appear in my ipad.
    Can somebody please tell me what I'm doing wrong. All five films were originally in AVI format. 2 of them are now in my ipad but the other 3 are not. The reason I want them on the ipad is because of a long flight coming up and they do not have in-flight entertainment on the plane. Any help would be very much appreciated.
    Kim
    PS... Also, I've noticed there is a small blue dot next to the films on itunes. This dot is a full dot or half a dot!! Sorry, but I don't know what that is.
    Supporting Vendor
    95402
    3 times
    Sep 2011
    429
    iPad supports both MPEG-4 and H.264 video.
    When you fail to sync some encoded MPEG-4 video to iPad, it could be that
    1) the original files are corrupted
    2) the source AVIs contains header and the converter can not handle them properly
    3) the settings (resolution, bit rate, frame rate) are not preferred by iPad
    4) your iPad is short of storage (HD movies bite much space
    So you may try encoding the movies with some other Video Converter app, and check if there's enough space to store the files.
    215170
    9 times
    Jun 2012
    Cape Town
    389
    To be honest , the best method I found is to buy an app that plays all movies, it then avoids this type of issue, I use Avplayer, it plays .avi. Mkv. Mp4 ....etc, you just drag and drop them on the app in iTunes no conversions required.
    242150
    Sep 2012
    San Francisco
    Try this: They might be in iTunes. If the files actually converted and you have a lot of these files, check the bottom of the other folders such as Music. If the File/Album name is not specified to dumps them all in one "Unnamed" list. If you find them, right click on the file (in a PC) and in the open dialog box select Get Info, go to the Options tab and set Movie or Video to move it in the right folder. Sometime ITunes resists this move or moves it into a different media folder, don't ask me why, so you might have to trick it by adding more info in the Info and Video tabs.
    A full/half dot is unplayed vs partially watched video/movie...
  1. How to Play MPG and MPEG files on new iPad 3
    By PavtubeVideo in forum Pavtube Software Studio
    Last Post: 05-11-2013, 01:54 AM
  2. 2 problems pls help
    By Wolfxkid in forum iPad Apps
    Last Post: 07-11-2012, 04:07 PM
  3. Converting AVI to MPEG?!
    By abiparker85 in forum iPad General Discussions
    Last Post: 04-20-2012, 09:09 PM
  4. Replies: 2
    Last Post: 10-11-2011, 09:48 PM
  5. Mpeg or avi to iPad.
    By Ultrimate in forum iPad General Discussions
    Last Post: 06-20-2010, 12:23 PM
apple ipad mpeg
bigasoft forums
mpeg 4 problems
mpeg problem
