IPAD won't charge above 3%
This is a discussion on IPAD won't charge above 3% within the iPad Help forums, part of the Apple iPad Discussions category; Good day someone may be able to assist me with Ipad 1 not charging using the 10w wall charger and I have tried several chargers ...
Results 1 to 5 of 5
    229001
    Jul 2012
    Gold Coast Australia
    it gove to 3% and displays that it is charging but does not go above
    1. have replaced battery {no better}
    2. restored to factory {no Better}
    3. Cold restore {no better}
    Have a missed something ??
    Regards
    Robert
    85546
    579 times
    Aug 2011
    Edmonton AB Canada
    9,852
    Don't think you've missed anything, but I'm no expert. Hopefully someone will come along who can shed some light on this.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    215170
    10 times
    Jun 2012
    Cape Town
    388
    Quote Originally Posted by RJT
    Regards
    Robert
    Sounds like a hardware problem, when you say you replaced the battery , was this done by an Apple technician?
    I ask because a decent techie would have checked the charging circuit and the old battery.
    42952
    Charlotte, NC
    Quote Originally Posted by Bosvaark View Post
    Got the same issue.. not sure about 3 percent as it never gets enough power to turn on. It does say its charging when I plug it in. Its definitely not the charger as the other 2 iPads are charging off same thing. Hope someone has a suggestion...
    1546 times
    Walla Walla, WA
    15,471
    Quote Originally Posted by titanflyer View Post
    Check to see if it's still under warrantee, and contact Apple. If it is under warrantee, they should replace it for free. If not, I believe a battery replacement costs about $100.
    https://selfsolve.apple.com/agreementWarrantyDynamic.do
  1. iPad 2 Will not Charge
    By Peter_Izn in forum iPad Help
    Last Post: 04-30-2012, 12:54 AM
  2. Ipad 2 won't charge.
    By Pully in forum iPad 2 Forum
    Last Post: 02-25-2012, 12:06 AM
  3. Replies: 15
    Last Post: 09-10-2011, 10:10 PM
  4. How often do you charge your iPad?
    By kheldour in forum iPad General Discussions
    Last Post: 05-01-2010, 05:06 PM
  5. ipad does charge using usb
    By jim_joh in forum iPad General Discussions
    Last Post: 04-15-2010, 09:23 AM
ipad 2 wont hold charge
ipad 5 won't charge
ipad battery not charging past 3%
ipad not charging past 3%
ipad won't charge past 1 percent
ipad won't charge past 2
ipad won't charge past 5
ipad wont charge past 2%
