Wifi & Mobile Data connection
This is a discussion on Wifi & Mobile Data connection within the iPad Help forums, part of the Apple iPad Discussions category; Hi, when my IPad is connected to wifi, the Mobile Data connection also remains active. Although, the internet/download is done through wifi connection, I can ...
Results 1 to 3 of 3
    219409
    Jun 2012
    9
    Hi, when my IPad is connected to wifi, the Mobile Data connection also remains active. Although, the internet/download is done through wifi connection, I can still see Mobile Data signal strength on the top left corner of IPad. In my view, the Mobile data signal must go off, once wifi is connected. Please advise. thx..
    13576
    748 times
    Aug 2010
    Western NY state (USA)
    9,298
    Quote Originally Posted by rajatnanda View Post
    That's normal behavior. Even though the WiFi is active, the cellular signal strength indicator will still show. As long as you see the WiFi "fan," though - you're good to go.
    Although I don't know for sure, I would assume that's so the cellular signal can jump right in should you lose your WiFi signal. That way, it will/would be a seamless transition. But, that's only my guess why...
    219409
    Jun 2012
    9
    Hi, Thanks for yr suggestion. You are right, when the wifi connection goes off, the cellular data is automatically connected immediately. Yeah, it's a seamless transition.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Tethering. Share mobile data connection
    By Porgee in forum iPAD Connect
    Last Post: 06-22-2012, 12:53 AM
  3. Icab mobile login data
    By Winam in forum iPad OS
    Last Post: 09-06-2011, 03:19 PM
  4. Using iPad with mobile data outside the UK
    By davethekeys in forum International iPad Users
    Last Post: 05-19-2011, 02:46 AM
  5. Replies: 3
connect wifi through mobile data
how to connect ipad wifi to cellular data
ipad cellular data wifi
ipad downloading cellular data when connected to wifi
ipad mobile data off when connecting to wifi
ipad wifi
ipad wifi mobile data
mobile data connection for ipad
mobile data on ipad
mobile to ipad connection
what is mobile data connection
what is mobile data on ipad
