Don't Want to restore my IPAD help!!!!
This is a discussion on Don't Want to restore my IPAD help!!!! within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I'm new to this forum, so hello everybody! I've bought an Ipad of a friend and I'm really pleased with it, first time I've ...
Results 1 to 6 of 6
    11728
    Aug 2010
    Hi,
    I've bought an Ipad of a friend and I'm really pleased with it, first time I've used an apple operating system, and finding it really easy to use.
    However I have a problem, I tried to use Sharepod with my ipad (which in hindsight I shouldn't have) and now when I log into itunes on my PC I get a 'Itunes cannot read the contents of the ipad, please restore'
    My understanding is that when I restore, my Ipad will be back to factory state and I'll lose all the apps I've paid for.
    I cannot back up my apps to itunes due to this problems. But the ipad itself is working perfectly. But it will not connect to itunes on my pc
    Is there anyway I can 'repair' my ipad so it will work with itunes without having to do a full restore or failing that am I able to save my apps without itunes?
    Any help will be welcomed with open arms!
    iPad Ninja
    772
    5 times
    Feb 2010
    Near Montréal Québec
    1,932
    Could you uninstall Sharepod and see what happens? What's the lesser evil?
    Not white, not black just passionate shades of grey...
    Yuno Wataï Minh
    11728
    Aug 2010
    I used sharepod from my PC, not on the Ipad so uninstalling sharepod wouldn't solve the problem.
    Thanks for the advice though
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    You should have all you music in itunes. apps can be downloaded again for free.
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    Yeah when you redownload apps you'll get a message that you already bought it and do you want to reinstall. Also, did you try uninstall share pod on pc, uninstall iTunes on pc and then reinstall iTunes to fix the issue? Or are you expecting compatibility once you restore? It would be a pain, if you got it all reset and then tried to sync again and get the same restore message.
    11728
    Aug 2010
    Many thanks for all your help
    I took your advice and restored my ipad, and as you said the apps i bought were reinstalled for free.
    Unfortunately the software my mate who i bought the ipad off has gone, but still I never paid for that in the first place.
    You're all very kind
    Regards!
  1. iPad cannot restore
    By dangrousperson in forum iPad Help
    Last Post: 11-06-2011, 09:31 PM
  2. [Help] iPad doesn't restore
    By BcBruno in forum iPad Help
    Last Post: 01-01-2011, 01:50 PM
  3. Can't restore iPad
    By winkness in forum iPad Help
    Last Post: 09-24-2010, 02:20 AM
  4. restore ipad from shsh or regular restore+jailbreak
    By bdaddy in forum iPad Hacking
    Last Post: 07-12-2010, 04:55 PM
  5. iPad restore
    By Caps in forum iPad General Discussions
    Last Post: 05-02-2010, 09:31 PM
don't want to restore ipad
i don't want to restore my ipad
if i reset my ipad will i lose my apps
if i restore ipad will i lose my apps
if i restore my ipad what will i lose
if i restore my ipad will i lose all my apps
if i restore my ipad will i lose my apps
ipad wants to restore
what happens if i restore my ipad
what happens when you restore an ipad
what happens when you restore ipad
what will happen if i restore my ipad
