WiFi Signal Strength Terrible
This is a discussion on WiFi Signal Strength Terrible within the iPad Help forums, part of the Apple iPad Discussions category; New here and this may have been discussed already, but here goes!-My MacBook, MacBook Pro & iPod Touch (1st Generation) all get a GREAT signal ...
Results 1 to 8 of 8
    11558
    Aug 2010
    Lincoln, ME USA
    15
    New here and this may have been discussed already, but here goes!-My MacBook, MacBook Pro & iPod Touch (1st Generation) all get a GREAT signal from our Airport Extreme. BUT, our iPod Touch (2nd Generation) and new iPad (WiFi) get terrible signal strength unless we're right next to the AE!! Tech support at Apple is of no help! I'm ready to sell them all! This all started when we got the last OS update for iPod Touch/iPhone/iPad. So it must be a software issue not a hardware one..
    We love the iPad and were planning on getting 2 more, but now.....Any ideas?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    #1 update ipad to latest firmware 3.2.1 this update has wifi issues fixed.
    #2 log into the airport Extreme and set encryption to WPA2 and then Change the Wifi Channel. Dont leave the channel on auto. If you have neighbors with wifi they could be interfering with yours, changing the channels to one that they are not using should help.
    #3 Do you have cordless phones in your house? Some cordless phone are known to interfere with Wifi. Unplug all cordless phone base stations and check if you still have problems with wifi.
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Run some scanning software on one of your macs and check out the local airwaves. Then switch to an unused channel.
    Sorry I can't advise as I'm win7 here.
    11558
    Aug 2010
    Lincoln, ME USA
    15
    Worked Fine Til iOS4 Update
    Everything worked fine on the iPods & iPad UNTIL the iOS4 update.
    11558
    Aug 2010
    Lincoln, ME USA
    15
    Using "automatic" Channel. Any suggestions on which channel to? use WPA/WPA 2
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Best channes of choice are 1, 6, and 11. But not if your neighbors are already using those channels. Try and find an open channel as far from other ones being used as possible. You can download the program called KisMAC for you MAC and see all the networks in reach of your house and what channels they are using.
    you can also try turning off auto brightness in iphone/ipad settings. iPad had wifi issues with autobrightness turned on, however this has been fixed in 3.2.1.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by MrLee View Post
    I find it interesting that you would have a WiFi problem with your iPad after you updated our iPod to iOS4 since there is no iOS4 for the iPad.
    11558
    Aug 2010
    Lincoln, ME USA
    15
    Maybe I got the # wrong. Anyway, it's the update in June I think it was- the last one.
  1. Droid X Drops Signal Bars Like iPhone 4
    By 4phun in forum iPad General Discussions
    Last Post: 08-02-2010, 06:17 PM
  2. Weak signal with Cisco M10 WiFi Router
    By jfdonohoe in forum iPad Help
    Last Post: 07-08-2010, 08:28 PM
  3. Weak wi-fi signal
    By rlee131 in forum iPad Help
    Last Post: 05-17-2010, 06:48 AM
  4. Signal boosters
    By geo in forum iPad General Discussions
    Last Post: 05-07-2010, 10:46 AM
  5. Wifi Strength?
    By Ray in forum iPad General Discussions
    Last Post: 04-08-2010, 09:05 AM
airport extreme low signal strength
airport extreme poor signal
airport extreme poor signal strength
airport extreme weak wireless signal
i pad no signal
ipad low signal
ipad no signal
ipad wifi signal strength
ipad wifi strength
itouch 2nd gen weak wifi signal
low signal on i pad
terrible signal on ipad 3
