sync doesn't work- Please Help
This is a discussion on sync doesn't work- Please Help within the iPad Help forums, part of the Apple iPad Discussions category; HeyGuys, When i connect my iPad2 to my computer, and open itunes, it is verified. I click on it from the Devices list, and sync ...
Closed Thread
Results 1 to 10 of 11
    184486
    Mar 2012
    40
    HeyGuys,
    When i connect my iPad2 to my computer, and open itunes, it is verified. I click on it from the Devices list, and sync it.
    BUT, non of the newly added Apps or Books gets transferred to the iPad. Knowing that they are checked in iTunes.
    Nothing is synchronized
    the apps checked in itunes are different from the ones available on the ipad!
    this doesn't happen on my iphone, just on my ipad...
    Have this been a common issue with anyone?
    1523 times
    Walla Walla, WA
    15,432
    I've never heard of this.
    Normally with sync issues I'd recommend you turn it off, let the content be removed, then turn it on to sync again: But this is a recipe for disaster with apps.
    One fairly harmless thing you can try is to do a Transfer Purchases. This might reset the sync. Right click on you iPad under the Devices list and choose Transfer Purchases.
    If that does not work, A few questions.
    Are you running the most recent version of iTunes on the computer?
    What iOS version are you running (and are you jailbroken)?
    184486
    Mar 2012
    40
    ok, so i tried Transferring Purchases... a somewhat of a progress, but the issue persists:
    some ebooks got transferred from the iPad to the laptop, and some song got transferred from the laptop to the iPad.
    But, the extra ebooks on the laptop that aren't on th iPad weren't transferred to the iPad (i have selected All Books in the books tab)
    and, the Apps didn't not sync at all! the Apps present on my iPad are different from the ones i have checked on my laptop in itunes. moreover, i have downloaded extra apps on the iPad, but they weren't transferred to itunes.
    This is frustrating... :/
    yes, most recent version of itunes. im running on IOS 5.1.1 on a jailbroken iPad 2.
    Note: i have an iPhone4S, and this doesn't not happen with it. it all syncs perfectly, unlike my iPad :/
    184486
    Mar 2012
    40
    UPDATE: the issue was resolved with everything (ibooks, music), but is still there with the Apps. Apps aren't synchronizing properly, same issue as mentioned above. Could there be some special settings for this thing? (both sync Apps and Automatically Sync New Apps are enabled under the Apps tab)
    1523 times
    Walla Walla, WA
    15,432
    Ok, just throwing out guesses now.
    Can you see and download the missing apps in the App Store on the iPad? Check under the Purchased tab. Same thing on the iTunes store for the computer. Can you see the apps that are missing from it under Purchased?
    If not, make sure both the iTunes store on the computer and the iPad are logged into the same Apple ID. Log out and in on the iPad in the App Store (bottom of the Featured tab). In iTunes on the computer it should show up at the top right. Same thing, make sure it's the same, try logging out and in.
    You do use the same Apple ID on both the iPhone and iPad, yes?
    One last thought. There are some apps for the iPhone that are not compatible with the iPad, and vice-versa. Those apps will not sync to the incompatible device no matter what you try. Same thing if the apps are not compatible with the iOS version on those devices. Check the descriptions of those apps in the App Store to be sure.
    Maybe that should have been a first though. Too late now.
    184486
    Mar 2012
    40
    yup, same ID.
    well yea, but i dont think that's my issue after revising the apps. plus, some downloaded apps on the ipad don't get synced to itunes, so that would be a different issue, right?
    1523 times
    Walla Walla, WA
    15,432
    Quote Originally Posted by MNFL
    yup, same ID.
    Most likely.
    I'm afraid I am out of ideas. Sorry.
    126685
    Nov 2011
    Isle of Wight UK
    This sounds similar to the problems I am having, and I have recented posted 'a really silly question'. I felt it was to do with the syncing of 3 gadgets and which one is done 'first' for instance if I add something to my i phone and sync this via the cloud it does not always go to i tunes and i pad because I have synced i pad to i tunes in the meantime if you get what I mean? and the 'first' sync is overridden because it is not on i pad and i tunes?
    184486
    Mar 2012
    40
    Most likely.
    is there a way to restart the sync? (as if its a new ipad connected) <-- without having to restore the ipad though, just the sync data
    1523 times
    Walla Walla, WA
    15,432
    Quote Originally Posted by MNFL View Post
    umm, i download my Apps using a piracy-enabling tweak but i've been doing this for years, and this have only happened now..
    I missed this earlier.
    I can offer you no more help. Piracy is a forbidden subject on this forum. You need to read the rules.
    I'm also personally against it, and I don't accept any of the popular excuses.
    Expect the admins to close the thread shortly.
Closed Thread
  1. on/off button doesn't work
    By ceedog in forum iPad Help
    Last Post: 07-24-2013, 05:47 PM
  2. Any app that I download doesn't work
    By mstiny in forum iPad Help
    Last Post: 05-23-2012, 05:39 PM
  3. Replies: 4
    Last Post: 12-26-2011, 02:04 AM
  4. The app doesn't work right...
    By M325i in forum iPad Apps
    Last Post: 06-14-2011, 09:08 AM
  5. Why doesn't my map work?
    By W4KRR in forum iPad Help
    Last Post: 12-26-2010, 09:15 AM
facebook doesn't work on ipad
ipad doesn't want to sync
itunes doesn't sync apps
itunes sync doesn't work
itunes sync wont work
my ipad doesn't want to sync
my ipad syncs with a computer that doesn't work
sync doesn't work
