Side switch not working
This is a discussion on Side switch not working within the iPad Help forums, part of the Apple iPad Discussions category; I just noticed today that games sound not working yet my music does; tried hard reset still d same; after reading some blogs, i realised ...
Results 1 to 9 of 9
    219755
    Jun 2012
    I just noticed today that games sound not working yet my music does; tried hard reset still d same; after reading some blogs, i realised that the prob was on the side switch. I already switch lock rotate and mute from Setting then turn off or on the mute or lock rotate logo from home button; i just cant seem to return it from the original setting: sound on while rotate on. Also when i tried to move the side switch up or down it doesnt show anymore the sound logo or rotate logo on the screen.
    Any suggestions guys. Hard reset; sync to itunes was already done and still it doenst work
    iPad Addict
    168139
    52 times
    Feb 2012
    Brisbane, Australia
    1,149
    Try clearing all the apps from the multitask bar. double click the home button to open it, touch and hold an app icon until it wiggles. Hit the red - to close the app. Do to each. This worked for someone with a similar issue here in the last day or so.
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
    97693
    510 times
    Sep 2011
    Michigan. USA
    15,366
    Hi there...I am going to move this to the Help section where you will get better attention. Right now it is in the POLLS section....
    ...and by the way, Welcome!!
    Thanks!
    219755
    Jun 2012
    Quote Originally Posted by dhewson777
    I always clear my multitask bar because somebody told me that it can also consume my iPads' memory. My concern is that the side switch, even if you move it up or down, sound logo or lock rotate logo doesn't show on screen. If you move down the side switch this should enable lock or mute, but it doesn't seem to work
    584 times
    Dayton, WA
    13,198
    If restart and reset are not working (I'm going to list them below, just so we know for sure we are talking about the same thing), I recommend trying Reset All Settings. (do not use the Erase All Content and Settings option)
    You'll find this under Settings > General > Reset.
    Chose the As new iPad option when offered.
    Despite being a bit scary looking, this will not erase any of your apps, content, or accounts. It will default a lot of your other settings, making it necessary to go though and re-tweak things to be the way you want.
    But it often fixes settings related problems. Especially right after an iOS update.
    219755
    Jun 2012
    Quote Originally Posted by twerppoet
    Tried it already but sad to say it didnt work..
    97693
    510 times
    Sep 2011
    Michigan. USA
    15,366
    By chance did you jail break your iPad??
    219755
    Jun 2012
    Quote Originally Posted by skimonkey
    Nope
    584 times
    Dayton, WA
    13,198
    Quote Originally Posted by ara_1914 View Post
    Then the only other thing you can try (that I know of) is a restore. Read up on it and make sure all your data is backed up; especially the data in the apps.
    If that does not do the trick chances are it is a hardware issue, and you'll have to go through Apple. Hopefully your warrantee is still good.
  1. Side by Side version 1.2 release (with promo codes)
    By 1234 in forum iPad App Announcements
    Last Post: 04-07-2013, 01:13 AM
  2. Side Switch - The settings
    By DickVanGelder in forum iPad Help
    Last Post: 07-20-2012, 07:37 AM
  3. Replies: 10
    Last Post: 12-26-2011, 11:51 PM
  4. Side switch set to Mute but not muting videos?
    By dlo in forum iPad 2 Forum
    Last Post: 11-26-2011, 10:54 PM
  5. Use ipad side switch for wifi on/off??
    By Kabona in forum iPad Hacking
    Last Post: 04-28-2011, 10:00 AM
ipad 2 side switch not working
ipad side button not working
ipad side switch not working
ipad sound button not working
ipad sound switch not working
iphone 4 side buttons not working
iphone 4 side switch not working
iphone side button not working
iphone side switch not working
side button on iphone 4 not working
side buttons on iphone not working
side switch ipad not working
