Having problems with the screen of my Ipad?
This is a discussion on Having problems with the screen of my Ipad? within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys, When I am opening applications from my Ipad it keeps turning black what seems to be the problem? not always just sometimes....
Results 1 to 5 of 5
    214954
    Jun 2012
    98
    Hi guys,
    214837
    Jun 2012
    Bangladesh
    98
    Resting or restoring will not work so better to contact to the Apple Care.
    579 times
    Dayton, WA
    13,189
    This often happens when apps run out of RAM or crash for other reasons. To a great extent it depends on the app, but it can also be a sign that the iPad's RAM is running low, or the system is struggling. If it is happening a lot you should try restarting or reseting the iPad and see if that helps. If it is app specific (that app keeps doing it) then you should try clearing that app from RAM.
    In case you don't know, here is how to do all those. None of them will damage or remove content from the iPad.
    214954
    Jun 2012
    98
    @twerppoet
    Thanks for the help sir its a specific app and I removed it.
    Now its working fine.
    579 times
    Dayton, WA
    13,189
    You're welcome.
  1. New Ipad screen Problems
    By EluciveArtist in forum iPad 3 Forum
    Last Post: 07-19-2012, 10:30 AM
  2. Touch screen problems - ipad 3
    By Shannonwillems in forum New Member Introductions - Site Assistance
    Last Post: 05-13-2012, 07:32 AM
  3. Ipad 3 Screen Problems?
    By GadgetQueen in forum iPad 3 Forum
    Last Post: 05-07-2012, 08:19 AM
  4. Problems with ipad2 Home Screen
    By Katb67 in forum New Member Introductions - Site Assistance
    Last Post: 03-02-2012, 02:36 PM
  5. Screen problems with ipad 2
    By steevo in forum iPad 2 Forum
    Last Post: 10-19-2011, 04:49 PM
having problems with my ipad
help ipad screen problem
ipad problems screen
ipad problems with screen
ipad screen problems
new ipad screen problems
problem with my ipad screen
problems in my ipad
problems with ipad screen
the screen to my ipad
whats going on to my ipad screen are getting black?
