Keeping wifi awake/alive when ipad (2) sleeps
This is a discussion on Keeping wifi awake/alive when ipad (2) sleeps within the iPad Help forums, part of the Apple iPad Discussions category; Hi! I have accsess to a wifi net at work that requires login at a special homepage. Everytime I close the smartcover the connection is ...
Results 1 to 4 of 4
    100035
    Sep 2011
    Stockholm
    Hi!
    I have accsess to a wifi net at work that requires login at a special homepage. Everytime I close the smartcover the connection is lost and I have to login again(typing both username and password). It's quite annoying and the Q is:
    Is there any chance I can keep the wifi connection alive/awake even if I close the smartcover or press the "on/off" button? It would be even better if this could apply to only that specific network!
    Thank you
    /Jan
    214837
    Jun 2012
    Bangladesh
    98
    You can use insomnia. It works in iPhone hope it will work on iPad too.
    214794
    Jun 2012
    99
    Have you update the firmware on your iPad? It is important to load the latest firmware to your router in this case.
    13576
    749 times
    Aug 2010
    Western NY state (USA)
    9,312
    When for had talks about the tweak Insomnia, he is mentioning something that can only be installed on a jail broken device. There is nothing you can do/install/download on a stock iPad that will prevent WiFi from turning off when your iPad goes to sleep. it's a power-saving function Apple designed into the iPad.
    However, if you iPad is connected to a power source and then goes to sleep, the WiFi will stay on. Cause it's getting power, so doesn't need to save it. So, try that and see if it helps? Yeah, you'll have to have any extra charger and cord at work, but still...
  1. Replies: 3
    Last Post: 10-14-2011, 01:20 AM
  2. Cover Problem? Ipad sleeps prematurely
    By nicled in forum iPad Help
    Last Post: 08-08-2011, 05:37 AM
  3. Keep iPad awake?
    By SweetPoison in forum iPad Hacking
    Last Post: 07-30-2011, 11:38 PM
  4. Keeping iPad awake
    By Grooveguru in forum iPad General Discussions
    Last Post: 06-08-2011, 06:27 AM
  5. Ipad still alive!
    By j0yful in forum Off-Topic
    Last Post: 10-31-2010, 10:59 AM
how to keep wifi on ipad
ipad keep alive
ipad keep connection alive
ipad keep wifi alive
ipad keep wifi connection alive
ipad keep wifi on
ipad keep wifi on during sleep
ipad wifi keep alive
keep wifi on during sleep ipad
keep wifi on during sleep iphone
keep wifi on ipad
prevent ipad wifi sleeping
Tags for this Thread
