USB Charging.......AHAAHHHHHHHHH!
This is a discussion on USB Charging.......AHAAHHHHHHHHH! within the iPad Help forums, part of the Apple iPad Discussions category; Ok....
I tried using the USB port on my PC to charge my IPod. Nothing.
So I do some research and I see that "old" ...
iPad Enthusiast!
Ok....
So I do some research and I see that "old" USB ports wont work...I need "new" USB ports....Ok.
I go out and buy a brand new USB 2.0 card, install it into my last open slot.....Drum roll please!!
Nothing.
WTF.
Does anyone have their IPad actually charging via USB?!?!?!?!?
07-31-2010 07:58 PM
iPad Master!
Not all USB ports on computers have enough juice to charge the iPad. Even if the computer is plugged in, you could still see a "Not Charging" message on your iPad when plugged in via USB.
Your best bet is using the wall charger.
iPAddict - 16Gig WiFi with Zagg InvisibleSHIELD Front - clear Hard Candy Sleek case - Built NY sleeve - Freedom Pro folding Bluetooth keyboard - Microsoft Bluetooth 6000 keyboard - Boxwave stylus - DIY LEGO stand, 3feet stand & DIY fold-flat stand
You can't use our PC USB to charge the iPad, because iPad need more power, form the stock charger you can see the different, is 10W...
It sounds like a driver issue on the PC tower or a Low voltage USB i don't understand why you do not use wall charger that is supplied. The only time I can see using a computer to charge would be in a situation where I have no power available and using a laptop even then it would drain the battery on the laptop if left to long. I suspect you have a low voltage USB card as the ipad requires 10v. I also assume iPad connects ok and syncs
iPF Super Guru
Its right there in the User Guide --
There is a bookmark to the online iPad User Guide in Safari or you can down load the .pdf from the Apple website.
I also recommend this for new users of iTunes it covers almost every thing one needs to know.
Hope it helps you.
Instant Expert: Secrets & Features of iTunes 9.1 (Updated) | iLounge Article
Yep, need 10 watts. Most PC's don't put out that kind of power on their USB bus. Fortunately for you, the iPad is smart enough to detect this and doesn't clamp on the power. Otherwise, you might end up with blown or at least disabled USB circuits...
Piko
Same Problem -try a Csquid
I had the same problem with my PC and iPad. I found a solution - it's called a CSquid cable. The info on it's website specifically talked about being able to solve this problem. Found it on Amazon and it works great!
iPad Master!
Originally Posted by
grngurrl
Yeah, this cable is great but if your USB port doesnt put out 10W of power you wont be charging at full speed.
still its better than not charging.
iPad Enthusiast!
I don't use the wall charger because I keep the wall charger at my office where I use the IPad the most and need a recharging option at home without having to spend another $30 purchasing a duplicate charger.
col.bris
- You may not post replies
- You may not edit your posts
Forum Rules
By Hawkmech in forum iPad General Discussions
Last Post: 08-12-2010, 10:54 AM
By HUNTER1 in forum iPad General Discussions
Last Post: 07-26-2010, 11:57 PM
By Sayishere in forum iPad General Discussions
Last Post: 07-25-2010, 07:31 PM
By Mexicat in forum iPad General Discussions
Last Post: 07-14-2010, 04:31 AM
By HarlyFan in forum iPad Help
Last Post: 07-12-2010, 09:51 AM
apple ipad usb charger
apple ipod charger circuit diagram
how to charge ipad with diagram
i phone usb charger cable pin out diagram
ipad cable pinout
ipad charger pinout
ipad charging resistors
ipad fast charger schematic
ipad usb cable pinout
ipad usb charger pinout
ipad usb pinout
iphone charge usb pinout
iphone charger cable diagram
iphone charger to usb pin diagram description
iphone usb charger circuit
iphone usb charger pinout
iphone wall charger schematic
usb charging circuit
usb charging pinout
usb pinout ipad
