USB Charging.......AHAAHHHHHHHHH!
This is a discussion on USB Charging.......AHAAHHHHHHHHH! within the iPad Help forums, part of the Apple iPad Discussions category; I understand that so that's why I purchased the USB 2.0 card (as USB 2.0 puts out greater power). Originally Posted by pik0 Yep, need ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    iPad Enthusiast!
    8027
    Jun 2010
    40
    Quote Originally Posted by pik0 View Post
    Yep, need 10 watts. Most PC's don't put out that kind of power on their USB bus. Fortunately for you, the iPad is smart enough to detect this and doesn't clamp on the power. Otherwise, you might end up with blown or at least disabled USB circuits...
    Piko
  2. #12
    iPF Super Guru
    7401
    5 times
    Jun 2010
    4,252
    There are aftermarket chargers from people like Belkin that are about half the price of the OEM charger.
  3. #13
    iPad Enthusiast!
    5964
    Jun 2010
    NJ
    31
    I plan to buy a second 10W charger, but until then am carrying stock charger back n forth daily.
    All my PC's are windows so no higher juice available there...
  4. #14
    4993
    3 times
    May 2010
    St.Louis Mo
    415
    Quote Originally Posted by windycitycouple View Post
    I don't use the wall charger because I keep the wall charger at my office where I use the IPad the most and need a recharging option at home without having to spend another $30 purchasing a duplicate charger.
    Quote Originally Posted by col.bris View Post
    It sounds like a driver issue on the PC tower or a Low voltage USB i don't understand why you do not use wall charger that is supplied. The only time I can see using a computer to charge would be in a situation where I have no power available and using a laptop even then it would drain the battery on the laptop if left to long. I suspect you have a low voltage USB card as the ipad requires 10v. I also assume iPad connects ok and syncs
    I went to the this site as soon as I bought my Ipad,I have a charger at home plus one in my travel pack. They are very cheap and they work fine. Not $30.OO,
    iPhone 3g Accessories, iPod Car Kit, Chargers, Headset, iPhone 3g Cover, Speaker Retailer
    Al.
  5. #15
    4993
    3 times
    May 2010
    St.Louis Mo
    415
    Quote Originally Posted by Al Rogers View Post
    Al.
    Sorry,
    I made a BOO BOO, that charger I bought was a 5Watt, and it was for my wifes Ipod,must have been a senior moment. SOooo Solly.
Sponsors
  1. Charging
    By Hawkmech in forum iPad General Discussions
    Last Post: 08-12-2010, 09:54 AM
  2. Charging?
    By HUNTER1 in forum iPad General Discussions
    Last Post: 07-26-2010, 10:57 PM
  3. Charging while using
    By Sayishere in forum iPad General Discussions
    Last Post: 07-25-2010, 06:31 PM
  4. charging the battery
    By Mexicat in forum iPad General Discussions
    Last Post: 07-14-2010, 03:31 AM
  5. Charging???
    By HarlyFan in forum iPad Help
    Last Post: 07-12-2010, 08:51 AM
apple charger usb pins configuration
apple ipad power cord plug pinout
apple usb charger schamatics
apple usb charger schematic
diy usb wall charger circuit
ipad charger pinout
ipad charger schematic
ipad charger wiring pinout
ipad charging adapter usb schematic
ipad charging circuitry schematic
ipad power adapter schematic
ipad power pin out
ipad usb charger pinout
ipad usb pinout
ipad usb schematic
ipad usb wire diagram
ipad2 charger pnout
pinout usb ipad
usb charger ipad pinout
usb pin out charging
