Problem Synching
This is a discussion on Problem Synching within the iPad Help forums, part of the Apple iPad Discussions category; Hi All, I'm having a problem syncing my iPad: - iPad 64Gb with 3G - recently added many movies to iTunes - reset iPad to ...
Results 1 to 7 of 7
    11082
    Jul 2010
    Shelburne
    Problem Synching
    - iPad 64Gb with 3G
    - reset iPad to factory settings after repeated failures to synch....now contains no music, movies or photos....just contact, calendar, apps.
    - iPad has up to date software
    - on iTunes I selected no music or photos to sync, and only last 10 videos
    - getting the following iTunes error message: "The iPad....cannot be synced because there is not enough free space to hold all the items in the selected playlists (64.20GB required, 55.63 GB available)"
    How do I get iTunes to sync? Any advice is greatly appreciated!
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Even though you have a 64gb iPad, the operating system takes up some of that as well as the apps that come with the iPad that you can not delete. Unfortunately you will not be able to put all of your movies on your iPad, at least not in their present format.
    11082
    Jul 2010
    Shelburne
    Problem Solved
    Thanks for your reply. I deleted all but a few movies to sync from iTunes and was able to sync successfully!
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by 1991-C4 View Post
    Not only that but he was trying to sync 64.20Gigs. Thats more than 64gigs.
    46156
    Cincinnati
    I have begund syncing videos to my Ipad- 64 GB. The "other" in the Capacity status bar jumps up to 12.5GB after syncing videos. I did a restore and started over. The other did drop to under 1GB. However after syncing it was back to 12 GB. The videos themselves take up 18GB. What is causing the other to go up to 12GB? How do I delete?
    115311
    Oct 2011
    Palm Bay, FL
    8
    I am having same issue. New IOS 5 update from Apple today. Tried to sync and it failed stated "ipad cannot be synch - required disk is missing disk cannot be found" Anyone with any ideas what "disk" it is looking for? I noticed when I first plug in my IPAD it opens to INTERNAL STORAGE. Does this have something to do with it? I have 32gb IPAD WiFi. No movies, some pics and a few videos. It looked for one music video and then crapped out with message above.
    "newbie" Tami
    115311
    Oct 2011
    Palm Bay, FL
    8
    I restarted IPAD and tried to re-sync and it worked.
  1. Synching photos FROM Ipad
    By windycitycouple in forum iPad Help
    Last Post: 06-25-2010, 10:29 PM
  2. icalendar not synching properly
    By Jayjayphoto in forum iPad Help
    Last Post: 06-04-2010, 09:57 PM
  3. Question about synching two ipads
    By iSoozin60 in forum iPad General Discussions
    Last Post: 05-24-2010, 06:53 AM
  4. iPad not synching with Dell running Win 7
    By Chicagofan in forum iPad General Discussions
    Last Post: 05-19-2010, 02:31 PM
  5. Synching Contacts/Windows 7 to Touch/Ipad
    By bap11 in forum iPad General Discussions
    Last Post: 03-22-2010, 02:40 PM
cannot be synced because there is not enough space
ipad cannot be synced because it cannot be found
ipad cannot be synced because there is not enough
ipad cannot be synced because there is not enough free space to hold all of the items in the itunes library
ipad cannot be synced not enough free space
ipad cannot sync because it can not be found
ipad cannot sync not enough space
ipad won't sync not enough space
the ipad cannot be synced because it cannot be found
the ipad cannot be synced because there is not enough free space to hold all of the selected items
the required disk cannot be found ipad
trying to update ipad and it says missing required disc
