Problem with the Numbers App
This is a discussion on Problem with the Numbers App within the iPad Help forums, part of the Apple iPad Discussions category; we are having problems with our work iPads. when we do spreadsheets in numbers on our iPads it looks good all on one page prints ...
Results 1 to 4 of 4
    213825
    Jun 2012
    Grande Prairie Alberta
    Lightbulb Problem with the Numbers App
    we are having problems with our work iPads. when we do spreadsheets in numbers on our iPads it looks good all on one page prints out nice, but then we email as pdf to our pc's(all MacBooks) and we get 4 pages all mixed up. Can anyone help me with this?
    Not sure if I am in the right place for this as I am a real noob to iPad, if not please send me in the right direction for answers
    579 times
    Dayton, WA
    13,187
    Are you by chance printing in Landscape? The PDF export only works in portrait (as far as I know). If you've got your spreadsheets layed out for a good landscape print, that would probably cause problems.
    There is a way for you get more control over your PDF layout. By using an app like FingerPrint or Printopia, you can print to a folder on a computer (with that app running on it). The result is a PDF. This way you can use the layout controls you see when printing from Numbers.
    213825
    Jun 2012
    thanks twerppoet. No we are printing in portrait. I set them up in excel on my macbook then switched them to numbers on my iPad then edited them there to make the spreadsheets. I will check out fingerprint and printopia. I am very new to apple so am learning a lot as I go.
    579 times
    Dayton, WA
    13,187
    No problem.
    The templates in Numbers all convert to PDF nicely.
    This is what I recommend trying. (no guarantee it will work)
    Open one of the templates and create a shape that covers (fairly accurately) the area used by that template. If you adjust it's transparency it should be fairly easy to adjust. You can even PDF the result to make sure it's working as expected.
    Copy the shape.
    Open your worksheet and paste the shape. Move it to the background, then make sure all your elements stay inside the bounds.
  1. Numbers
    By hberninger in forum iPad General Discussions
    Last Post: 05-14-2012, 06:28 PM
  2. Replies: 3
    Last Post: 03-17-2012, 07:44 AM
  3. Replies: 1
    Last Post: 02-15-2012, 09:40 PM
  4. IPad Numbers Problem
    By JWhitTX in forum iPad Help
    Last Post: 10-27-2011, 06:29 PM
  5. Column/Row letters/numbers in Numbers
    By MikeV99 in forum iPad Apps
    Last Post: 07-22-2011, 02:10 PM
ipad new numbers problems
numbers app
numbers app ipad problem
numbers app issues
numbers app problems
numbers app trouble
numbers ipad problems
numbers problems on ipad
pdf reformatting
printing problems with numbers on ipad
problems loading numbers app on ipad
problems with numbers ipad
