iTunes Match Problem
This is a discussion on iTunes Match Problem within the iPad Help forums, part of the Apple iPad Discussions category; So I've been using the match service for a couple of weeks now. I have a very limited amount of space left on my iPad ...
Results 1 to 1 of 1
    210180
    May 2012
    murray70@msu.edu
    So I've been using the match service for a couple of weeks now. I have a very limited amount of space left on my iPad so I'm constantly deleting the songs that get downloaded once I've played them. What's weird is that, at the moment, all the songs that were downloaded have been deleted by manually editing the music app, but when I look under settings at the list of songs, videos, and used and free space, on my iPad it says I have over 70 songs. They don't show up in the music app so basically they're no where to be found. My iPad also says I have 27 videos, but the only videos under that app are music videos that were matched when I uploaded my library to the cloud. None of which appear to be downloaded. I'm new to the forum and did a quick search to find any threads that might contain a solution, but no luck. I'm down to my last 100 mb, so finding a way to delete these files is my biggest concern. Any help would be greatly appreciated. Thanks!
  1. iTunes Match!
    By Daylife in forum iPad 3 Forum
    Last Post: 03-19-2012, 06:20 AM
  2. Itunes match is the worst!!!!!
    By jthessin in forum iPad OS
    Last Post: 02-24-2012, 07:05 AM
  3. iTunes Match Thread
    By richsadams in forum iCloud
    Last Post: 01-10-2012, 07:18 PM
  4. Itunes Match question
    By Dshow in forum iPad Help
    Last Post: 11-12-2011, 09:34 AM
  5. ITunes Match is now turned on.
    By stevnim in forum iPad OS
    Last Post: 10-21-2011, 07:47 PM
i match
ipad itunes match problem
ipad3 itunes match problem
ipadforums itunes match
itunes match
itunes match faq
itunes match forum
itunes match problem on ipad
itunes match problems
itunes match problems 2012
itunes match problems ipad
problems getting itunes match onnipad 3
