iPad won't display some ASP.net webpages
This is a discussion on iPad won't display some ASP.net webpages within the iPad Help forums, part of the Apple iPad Discussions category; A website that works fine on PC's and Apples does not display/open some ASP.net webpages on the iPad. The webpages are unique from those that ...
Results 1 to 2 of 2
    10834
    Jul 2010
    Colorado
    The webpages are unique from those that iPad does open in that they are all dynamically created reports i.e. all of the controls are created dynamically as needed to accommodate the data.
    iPad Master!
    1474
    2 times
    Mar 2010
    Marietta, GA - USA
    738
    Used the iTeleport application and view the web pages rendered on some other computer using VNC connection. That way you can even view flash enabled web sites on the iPad if you need to.
    iTeleport has a delay of about one second over wifi and several seconds over 3G.
    iTeleport got its start as jaadu VNC.
    Do a Google search for "best VNC iPad" for more information.
  1. Ipad display problem
    By ZeeDD in forum iPad Help
    Last Post: 07-25-2011, 04:37 PM
  2. OLED Display for iPad?
    By RickD_99 in forum iPad General Discussions
    Last Post: 06-02-2010, 09:18 PM
  3. iPad display bug
    By jameslawson in forum iPad Help
    Last Post: 06-02-2010, 05:31 AM
  4. AIr Display Ipad app looks cool
    By jules in forum iPad Apps
    Last Post: 05-25-2010, 12:01 PM
  5. I did it!! Display anything from your iPad
    By Zip in forum iPad Hacking
    Last Post: 05-14-2010, 03:40 PM
asp and ipad
asp for ipad
asp ipad
asp on ipad
asp.net file won't open on ipad
asp.net page will not display correctly in iphone or ipad
ipad asp
ipad aspx
ipad.asp.com
view aspx on ipad
webpage content not displayed on ipad
what to use on web page for displaying on ipad
