how i can cek my quotq in my ipad 2 3g
This is a discussion on how within the iPad Help forums, part of the Apple iPad Discussions category; how i can cek my quotq in my ipad 2 3g...
Hi there-can you be more specific? I am not sure if I understand .
I believe OP is asking how to check data usage vs data quota on a 3G data planOriginally Posted by skimonkey
Try settings>general>usage>cellular usage.This will give you the total cellular data used by your iPad since the data was last reset.There is a reset feature at the bottom of the cellular data usage page.You could reset the data usage at the beginning of each billing cycle.This would enable you to keep track of how close you currently are to your monthly data limit.
