Ipad 2 power button problem
This is a discussion on Ipad 2 power button problem within the iPad Help forums, part of the Apple iPad Discussions category; I recenly bought a replacement digitizer, wi/fi cable and a new power flex cable for my Ipad. Once installed, I attempted tp test it before ...
Results 1 to 2 of 2
    203008
    May 2012
    I recenly bought a replacement digitizer, wi/fi cable and a new power flex cable for my Ipad. Once installed, I attempted tp test it before final assembly and nothing happened. Then I noticed that the microswitch for the power button does not move. I believe that the power flex cable is the problem. However, when I plug in the Ipad to charge it, it makes a sound like its charging, but the lcd screen does come on to show that it is charging. If the power button is stuck/ damaged, could that cause the screen not to come on? Any suggestions????
    254083
    Oct 2012
    Wichita KS
    Screen replacement
    Quote Originally Posted by Houdini40 View Post
    I have found when replacing the digitizer for Ipads that the screen will stay dark until you hold power button and home button to "reboot" it.
  1. iPAD POWER BUTTON STUCK!
    By semajmik in forum iPad Help
    Last Post: 05-12-2012, 07:54 PM
  2. Power Button & Home Button Sometimes Acting Weird
    By shakra00 in forum iPad General Discussions
    Last Post: 04-11-2012, 02:07 AM
  3. Replies: 13
    Last Post: 11-24-2011, 09:27 PM
ipad 2 power button does not work
ipad 2 power button does not work after replacing digitizer
ipad 2 power button install
ipad 2 power button not working
ipad 2 power button not working after screen replacement
ipad 2 power button problem
ipad power button not working
ipad power button not working after screen replacement
ipad power button stuck
ipad2 power button not working
power button not working after ipad screen replacement
replaced digitizer now power button not working
