section "other" is more than 50 gb
This is a discussion on section "other" is more than 50 gb within the iPad Help forums, part of the Apple iPad Discussions category; After tranfering a number of large files via filebrowser my "other" section is 53 Gb. What I can do now to clear it up? I ...
Results 1 to 10 of 13
    195529
    Apr 2012
    St.Petersburg, Russia
    9
    After tranfering a number of large files via filebrowser my "other" section is 53 Gb. What I can do now to clear it up? I tried to sync the Ipad with itunes several times. But that didn't help. Help!
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    Quote Originally Posted by parsprototo
    iBooks, audio books, comic books etc are typical offenders. Try a cleanup in that area for starters.
    Application user data use other space too. Big offenders are offline readers like goodreader. Go through your apps and pull up settings within the app and clear stored content where applicable.
    Also seems a corrupt file or files from a sync could do this. Only way out if this is the case is factory reset.
    195529
    Apr 2012
    9
    Thank you for reply.
    All my apps folders are clear (including VLC folders).
    I think: this is caused by fragments of transferred files which got "stick" in memory. The "open in" feature has its limitation: it only alows your transfer files up to 350 mb. Anf I tried to transfer larger files (1-2 Gb) over and over again. The transfer failed. But my memory suddenly became full (59 Gb). And now I cannot cleare it up. In fact my Ipad is nearly empty: I deleted all media content. But I can't find out where these 50 Gb should be. It's strange that Apple doesn't have some simple app to clear the garbage. PC (hello, I'm PC) has it for ages. Not to mention the limitation for "open in" (350 mb) which is really stupid and makes filebrowser etc. almost useless. Sorry for my english...
    193958
    26 times
    Apr 2012
    Alba
    399
    There is a good guide here
    osxdaily.com/2011/10/18/itunes-other-capacity-taking-up-tons-of-space-fix/
    Sent from my GT-I9100 using Tapatalk 2
    CLOSING APPS: If an app has stopped responding or closes on launch, try the following: * Home screen * click the Home button twice * Tap and hold on the app * When it jiggles, tap the (-) to close it * Double-click the Home button and re-open the app
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    If you look around there are utilities that allow you to browse(and subsequently) manipulate items in a backup. You backup, you modify the backup, you restore from the backup and viola. If you cannot locate shout.
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    If unable to identify and delete the problem objects then I am afraid RFS (restore factory settings or really freakin stupid) is the only alternative.
    I will look around for that backup edit tool when I get to the office. Right now COFFEE and more coffee then off to work
    195529
    Apr 2012
    9
    Thank you
    Will wait on your post
    85546
    579 times
    Aug 2011
    Edmonton AB Canada
    9,852
    I assume you mean VLC that was pulled from the app store. I also have this app and have found that if you use it to play a video it does not release the storage.
    The only workaround I have found is to uninstall the app and reinstall it through iTunes.
    Sent from my iPad 4 HD mini
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    Thank you
    Ibackupbot
    195529
    Apr 2012
    9
    Thank you all for help, especially Midranger 4
  1. Replies: 5
    Last Post: 04-29-2012, 04:55 PM
  2. Replies: 6
    Last Post: 04-20-2012, 10:46 PM
  3. Any other games like "Words with Friends" or "Pirate Battle?"
    By Lend27 in forum iPad General Discussions
    Last Post: 03-21-2012, 06:30 PM
  4. Replies: 21
    Last Post: 03-16-2012, 04:38 PM
  5. ipad storage "Other" section
    By Sonicrobby in forum iPad Help
    Last Post: 06-09-2011, 09:58 PM
iphone other space too large
itunes other capacity
itunes other capacity fix
itunes other capacity huge
itunes other capacity taking up tons of space
itunes ?other? capacity taking up tons of space?
large other space gb ipad
what is itunes other capacity ipad3
