Sound working only in earphones, not speakers on iPad 3
This is a discussion on Sound working only in earphones, not speakers on iPad 3 within the iPad Help forums, part of the Apple iPad Discussions category; courtesy Traceygee Adding another thing to try. I have an iPad that had sound for iTunes and movie playback only, and all other apps, including ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
Like Tree2Likes
Thread: Sound working only in earphones, not speakers on iPad 3
  1. #11
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    courtesy Traceygee
    I have an iPad that had sound for iTunes and movie playback only, and all other apps, including games, had zero sounds after the update. I did have lock sounds, but no keyboard sounds even though those were both set on.
    I rebooted several times, did the toggle on the mute switch as suggested and nothing.
    I went into the "sounds" area on settings. Toggled both the lock sounds and keyboard sounds OFF, did a reboot, then went back in and toggled both lock sounds and keyboard sounds ON. This brought back not only my keyboard sounds, but also the sounds on all my games and apps. It's worth a try if the other things don't help.
    Like (0)
  3. #12
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    Check MUSIC/VOLUME LIMIT.
    Set to NO if set to YES
    Check For the volume slider again by double tapping home button and swiping right.
  4. #13
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    Been reading every post I can find on this subject.
    I do not mean to be insulting so please bear with me.
    When you checked the general setting what was the use side switch set to (lock rotation or mute) and what is it set to now?
    Set property to mute....then flip side switch to mute position ( you will see a red dot appear on the switch when you do).
    Now unmute
    Now test.
    The switch should be set to no mute (with no red dot visible) before changing the general setting.
    If this fix doesn't work the only other causes I've located is a dirty pin number 21 on the ipad port (google clean pin 21) or hardware failure on the heaphone jack...both highly unusual.
  5. #14
    230941
    Jul 2012
    England
    No sound iPad 3
    Tried all suggestions to no avail..... Then after going into Settings - music - and turning every heading on off on and changing Equaliser settings back and forth, when I retried music I got sound back!!! What's going on there????
  6. #15
    235118
    Aug 2012
    Hi,
    I have the same issue. My ipad is only playing sounds when connected to the headphones and have tried all of the above with no success. Any other suggestions?
  7. #16
    235118
    Aug 2012
    further to this, I definitely think it has got "stuck" on the lock mute/thing as sometimes I will change the settings, reboot, and then go back and the changes have not stuck
  8. #17
    245877
    Sep 2012
    USA
    Thanks Fid. your solutions for my sudden loss in volume involving running apps in the background combined with shut off/on did the trick for me. I was shocked to see that EVERY app I had was running in the background. Thought that was really strange and will want to investigate further.
  9. #18
    247371
    Sep 2012
    New York
    Fid you are a legend! This solved my problem perfectly. Thanks heaps!!!
  10. #19
    251065
    Oct 2012
    Toronto
    Hi folks,
    I also am having this problem.
    Sounds work on my speakers (i.e., alerts), but iTunes, videos, etc., do not work.
    I have my mute unlocked. There flat out isn't a sound bar to adjust - it just appears as an empty bar with no ball to slide up or down.
    When I put my headphones in and pull them out, my sound bar will return and it will work, but if I try to adjust it, it will disappear again and the sound will become totally muted.
    If I double tap the home button and slide the bar over, I can restore the audio if I mute and unmute using the mute button on the right side.
    And, yes, I have closed all apps and rebooted the iPad.
    Should I be taking this to a Genius Bar?
  11. #20
    275190
    Jan 2013
    please help - i have IPAD 3 about a week ago the sound on speakers started crackling, now the sound is off completely.
    Is this an Apple issue with the Ipad 3?
    I have powered off IPAD now not sure what to do next. I am also not in the country where i bought the Ipad
    thanks Debbie
  1. no sound with speakers, only earphones
    By Blu3Moon in forum iPad Help
    Last Post: 01-15-2013, 10:39 PM
  2. Ipad 1 speakers not working.
    By garymarch in forum iPad Help
    Last Post: 05-12-2012, 06:55 AM
  3. iPad2 sound doesn't work without the earphones/headset
    By iRumi in forum New Member Introductions - Site Assistance
    Last Post: 01-06-2012, 06:08 PM
  4. No sound with speakers plugged in
    By Mmwscooters in forum iPad Help
    Last Post: 09-08-2011, 05:37 PM
  5. Replies: 0
    Last Post: 11-19-2010, 12:32 AM
ipad 3 no sound without headphones
ipad 3 sound not working
ipad 3 speaker not working
ipad 3 speakers not working
ipad sound not working
ipad sound not working without headphones
ipad speaker not working
ipad speakers not working
