iPad 3 Connectivity to WiFi
This is a discussion on iPad 3 Connectivity to WiFi within the iPad Help forums, part of the Apple iPad Discussions category; I have a 16 gb iPad3, wifi only, and this is the first iPad I've had (though I've been an Apple Mac user since the ...
Results 1 to 10 of 12
    196116
    Apr 2012
    UK
    I have a 16 gb iPad3, wifi only, and this is the first iPad I've had (though I've been an Apple Mac user since the early days). When I first connected up to my wifi at home, everything was fine. Ever since I connected to wifi at a friend's house, however, I haven't been able to maintain my connection at home. "Cannot Get Mail: The connection to the server failed." "Cannot Open Page" "Not connected to the internet" - and this is despite the fact that a good signal is showing. We googled this problem - found a lot of fellow sufferers - but nothing anyone suggested doing has worked. Any advice? Is this a bug? If so, will it be fixed soon?
    Any information gratefully received -
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hello JGS - welcome to the forum!
    I would first go into settings and have the iPad 'Forget' your home network, then try to re-establish a connection; if not effective, then power recycle your modem & router, i.e. pull the power (or turn off if a switch if present), wait a while, then in sequence, plug in the modem first followed by the router - I need to do this about once a month.
    If the above is not helpful and if not already done, 'Restart' or if of no help 'Reset' the iPad - directions HERE, if not familiar w/ the maneuvers - good luck and please post back your results; may help others!
    200604
    May 2012
    United States
    I've tried the reboot, the restart, the reset on my ipad2 and nothing has helped. Once I changed the numbers on the DNS to match the # on my ipod touch and that worked for a day. Now that won't work either. I would appreciate any help you guys have.
    48665
    484 times
    Brisbane, Australia
    19,277
    Hi and welcome to the Forum!
    Have a look at this link, I hope it helps you
    http://support.apple.com/kb/TS1398
    iOS5 Tips and Tricks
    iPad 2 64gb 3G
    196116
    Apr 2012
    UK
    Thanks. I've tried all of the above, and none of them worked. Resetting the router worked for about five minutes before my iPad once again lost the connection to the internet. From online searches - and tinahallmark's response above - I gather I'm not the only one with this (extremely annoying) issue.
    Any further suggestions would be very gratefully received.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Sorry JGS about your continuing problem and frustration - not sure that I can add much beyond the suggestions given in the linked Apple Support article provided by Leelai; I was going to suggest updating your router's firmware (helped me a few years ago). Just curious but does your iPad's Wi-Fi connect on other networks and can other Wi-Fi devices connect to your home network? Just trying to pinpoint the problem as possibly isolated to the iPad vs. the router?
    Well, keep us informed and hope others will 'chime in' to help -good luck!
    196116
    Apr 2012
    UK
    Thanks, Giradman - I really appreciate you trying to help me. What's so mysterious is that the iPad was working perfectly at home until I took it on its first outing and connected it to another network - which also worked just fine. When I came home, that was when I noticed that it was no longer connecting to the internet, though it indicates that it's receiving a good signal. When I look under Settings/Network/Wifi, however, our network isn't ticked off - it just has the whirry circle next to it. So, I guess it's trying to connect - unsuccessfully.
    The router's firmware is up to date - and all other devices, such as the computer I'm working on now, my partner's computer, our iPhones - all connect just fine.
    As I said, resetting the router worked for about five minutes.
    So, today it just so happens I'm going back to where I connected it away from home the other day - and my big idea is to 1) see if it still connect to that network and 2) if it does, to "Forget" that network. We'll see if that makes any difference.
    This feels like the old days of Apple magic - when you used to have to open your chunky old Apple computer to jiggle the circuit boards and chant an incantation. You never knew what was going to work...
    196116
    Apr 2012
    UK
    Update: my magic spell didn't work - not that I expected it to, as the network would have been forgotten anyway when I reset. But I was able to connect to the other network - download e-mails, etc., etc.
    So I now officially have an iPad3 that works everywhere but home. Even though it used to and even though all other devices work just fine. Very, very odd.
    48665
    484 times
    Brisbane, Australia
    19,277
    I've moved your thread to our Help Section where I'm hoping more members will see this and hopefully someone may be able to help you.
    iPad 2 64gb 3G
    106673
    Oct 2011
    10
    I've been having these problems, on and off for a couple of months now and must admit I'm sick to death of it. I've tried every 'solution' on here and from apples support forums and if any of them work they do so for a day or two before the dropped wifi returns. I'm talking about every 5-10 minutes or so.
    We also have an iPhone and a touch on the go and they don't have the same problems, maybe just every now and then, but the iPad is becoming unusable as far as wifi around the home is concerned.
    Apple must know about it because a google brings up thousands with the same problem but there is no acknowledgement that there is a serious issue.
    Seriously, this problem heeds to be faced and we need to know it is being so. I've paid £400 for something that at the moment is as reliable as dial up. It's gone twice whilst typing this!
  1. IPAD PPTP WIFI Connectivity Problems
    By aga2571 in forum iPad Help
    Last Post: 08-26-2012, 02:50 AM
  2. 3G with wifi connectivity issues
    By Diane B in forum iPad 3 Forum
    Last Post: 04-05-2012, 01:01 PM
  3. Ipad 2 wifi fading connectivity
    By lisa1234 in forum New Member Introductions - Site Assistance
    Last Post: 12-12-2011, 04:47 AM
  4. Problem with Wifi connectivity with my iPad
    By zoombieland in forum iPad 2 Forum
    Last Post: 11-04-2011, 10:06 AM
  5. Ipad & Apple TV Connectivity via WiFi?
    By Marilyn G in forum AirPlay
    Last Post: 04-11-2011, 10:46 AM
best way to connect ipad3 to internet
connecting ipad3 to the internet
how to connect ipad 3 to internet
how to connect to wifi with ipad3 wifi
how to connect wifi on ipad 3
ipad 3 connect to internet
ipad 3 connectivity
ipad 3 internet connection
ipad 3 internet connection problems
ipad 3 not connecting to wifi
ipad 3 problems with internet connection
