Facebook problem
This is a discussion on Facebook problem within the iPad Help forums, part of the Apple iPad Discussions category; I think you all need to do the usual fixes for a start and then we'll see how you go. Although it is strange that ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
  1. #11
    48665
    946 times
    Brisbane, Australia
    23,479
    I think you all need to do the usual fixes for a start and then we'll see how you go. Although it is strange that there are a few of you all having the same issue. The first step is to close the app completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly, I do mine every night. Check and see if it is operating now, if not a restart is in order.
    Restart: Press and hold the power off button, the one at the top right. You will see a slide appear to power off, slide this and the screen will go dark and a Whirly will appear. When the Whirly disappears your iPad is now off. Press the power button again until the Apple logo appears, this will take a few seconds and your iPad will restart. You should restart your iPad occasionally also as it will keep it running well. Now see if it is operating. If not a reset is the next step.
    When an App or your iPad begin to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
  3. #12
    200255
    2 times
    May 2012
    9
    I have even done a ipad restore..and have tried out all your steps already before posting here...
  4. #13
    200292
    May 2012
    Same here. The newsfeed screen is black and the steps are not working....
    I have notified the Facebook technical support team, hopefully they can do something about it.....
  5. #14
    48665
    946 times
    Brisbane, Australia
    23,479
    As this looks like a Facebook issue with the app, it might be an idea to get in touch with the Developers and inform them what is happening.
  6. #15
    200815
    May 2012
    Singapore
    I am facing the same problem too. Hopefully someone can find a solution.
  7. #16
    201313
    May 2012
    Singapore
    Oh I have this prob too! Juz started suddenly!!
    Hope there's an update soon!
  8. #17
    201356
    May 2012
    I have exactly the same problem...did what I should have done...but Facebook newsfeed still showing blue screen...-_- very frustrating...
  9. #18
    200815
    May 2012
    Singapore
    Try to close all the running apps. Especially game apps. After doing that I managed to get my FB news feed back.
  10. #19
    201313
    May 2012
    Singapore
    Still not working for mine! iPhone apps works perfectly well though
  11. #20
    202738
    May 2012
    I am having the same problem too!!! Are you guys Singtel subscribers? If u are, u may wanna try to turn on ur hotspot to connect to another telco. It works. But of course this doesn't solve the problem (
  1. Facebook problem
    By GreenWoman in forum New Member Introductions - Site Assistance
    Last Post: 01-01-2012, 11:07 PM
  2. Facebook Problem
    By Steve2150 in forum iPad 2 Forum
    Last Post: 11-19-2011, 09:43 PM
  3. Log to facebook problem
    By msaleh in forum iPad Help
    Last Post: 10-03-2011, 11:10 AM
  4. Facebook app problem
    By Sostar in forum iPad Apps
    Last Post: 09-29-2011, 01:23 PM
  5. facebook view all problem
    By Ldcaudle in forum iPad Help
    Last Post: 07-08-2010, 09:01 PM
account already connected in words with feiends on ipad
cannot see news feed on facebook on ipad
cannot see newsfeed on facebook ipad
facebook for ipad problems
havin problems getting news feed from facebook on ipad
having trouble with new ipad air with my facebook
ipad facebook app problem
ipad words with friends account already connected
