iPad 2 + iOS 5.1 + Verizon DSL (Westell router) + Netgear WNDAP350 AP = Problems
This is a discussion on iPad 2 + iOS 5.1 + Verizon DSL (Westell router) + Netgear WNDAP350 AP = Problems within the iPad Help forums, part of the Apple iPad Discussions category; I'm a computer engineer and should be able to diagnose the repair this problem, but iOS is new to me... My iPad2 (iOS 5.1) is ...
Results 1 to 2 of 2
    198569
    May 2012
    Monroeville, PA
    My iPad2 (iOS 5.1) is configured for both my home and work WiFi. (the subject line is home config).
    Safari looks to work fine at home and at work. So I have basic connectivity. BUT email and other Apps work fine at work but DO NOT have network connectivity when at home. I have iCloud, Gmail, and Verizon email access configured. NONE of them connect at home, but all work fine at the office (so it's NOT a particular email client setup issue).
    Tonight I'm going to use Wireshark in an attempt to diagnose what is on the WiFi and/or wired LAN. I looks like DNS might not be working (I'll try explicit IP's). But DNS works ok on HTTP connections.
    Other wired and wireless machines around the house have no problems accessing the same email services. But like I said, I have limited iOS knowledge.
    Any thoughts?
    198569
    May 2012
    Monroeville, PA
    OK..
    After a lot of reading and learning, I edited the firewall configuration on the DSL router and NOW have proper email function.... The ports were blocked..
    ...Never Mind...
  1. Replies: 1
    Last Post: 02-05-2012, 12:16 AM
  2. Unable to connect Ipad 2 to netgear router
    By georgyb99 in forum iPad Help
    Last Post: 01-19-2012, 12:05 PM
  3. Getting my ipad 2 to listen to my Netgear router
    By seananton in forum iPad Help
    Last Post: 05-12-2011, 06:27 AM
  4. netgear router
    By grotta365 in forum iPad 2 Forum
    Last Post: 04-11-2011, 06:46 AM
  5. Westell router problem
    By iceman in forum iPad Help
    Last Post: 06-03-2010, 08:33 AM
cant get dsl to work on ipad
connection of ipad to dsl
ipad 2 verizon wireless router problem
ipad verizon router setup
ipad2 map not sync with netgear
netgear router ipad issues
router for ipad 2
verizon connectivity ipad2
verizon router ipad problems
westell ipad connection problem
wndap350 blocking email sync
wndap350 ipad
