wifi connection
This is a discussion on wifi connection within the iPad Help forums, part of the Apple iPad Discussions category; Hi all - I am a complete newbie so please be gentle. I have just bought a ipad 3 (not 3G) and would to know ...
Results 1 to 4 of 4
Thread: wifi connection
    198585
    May 2012
    wifi connection
    I have just bought a ipad 3 (not 3G) and would to know the best way get Internet access.
    This will be on apartment complex in Turkey where there is no wi-fi.
    Can a router be hired ?
    There are of course loads of bars where there is wifi.
    the thing that puzzles me is that I know a wifi dongle can be hired by the week - but the ipad has no USB slot.
    I have seen a little connecter - ipad at one end and USB (female) at the other so could I put the dongle in there ?
    Many thanks
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Quote Originally Posted by sswf224
    Many thanks
    You will need to access wirelessly. There is no adapter to hard wire the iPad into an Ethernet connection.
    You say the apartment complex has no wifi. Are there internet service providers in your area that might provide you service? I know of a provider her in the US (Clear) that is a monthly service that provides you a wireless router with internet access.
    Their routers use 3G (cellular signal) as the conduit to the internet so you only need cellular service available where you are located for a service like this to function.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Quote Originally Posted by sswf224 View Post
    the thing that puzzles me is that I know a wifi dongle can be hired by the week............
    Hello and welcome to the forum!
    As you know, your new iPad has Wi-Fi built in so that is the signal the device needs to detect, regardless of the source. Some excellent comments have already been made, e.g. obtaining a wireless router in your apartment using a local ISP provider.
    Another consideration (and not sure about its availability in Turkey) is Mi-Fi (an example HERE) which is basically a way to setup a mobile Wi-Fi hotspot using a 3G or 4G cellular signal - the small portable device needs to be purchased along w/ a data plan. Thus, you have plenty of options - good luck and let us know your solution!
    79592
    Jul 2011
    Monroe, GA
    11
    Purchase an inexpensive Wireless N router. Any old Belkin or Linksys will work. Plug it into the wired Internet access then you will have WiFi.
    I had to do this on each visit to Walt Disney World until the finally got with the times and installed WiFi for guest use.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Very low wifi connection!
    By andrejbruno in forum iPad General Discussions
    Last Post: 09-28-2011, 02:54 AM
  3. Replies: 3
    Last Post: 06-04-2011, 08:16 AM
  4. WiFi connection
    By fusdma in forum iPad Help
    Last Post: 12-13-2010, 02:11 PM
  5. Replies: 3
best way to have ipad wifi and internet at home
dongle for ipad wifi
hard wired internet connection to ipad
how to get internet signal to ipad 3 from ethernet
ipad ethernet
ipad ethernet dongle
ipad no wifi connection
ipad wifi disney world
take ipad to disney world wifi
wifi connectivity for ipad in turkey
wifi dongle for ipad
wifi dongle turkey
