Pls help having issues with blank apps
This is a discussion on Pls help having issues with blank apps within the iPad Help forums, part of the Apple iPad Discussions category; Hi, The other day i had a game freeze on me so i deleted it. Now i go to my music, books or app store ...
Results 1 to 2 of 2
    124628
    Nov 2011
    Hi,
    The other day i had a game freeze on me so i deleted it. Now i go to my music, books or app store and they open but nothings there. In books the shelves are there but nothing else. In apps store its just a blank screen and in the music the buttons are there but all is blank.
    Please help me i have opened up other apps and stuff and they are fine so im confused.
    33574
    25 times
    Feb 2011
    Levittown pa
    678
    Try standard memory cleanup and restart described below:
    Close all background apps. Double tap home button. Active task bar appears tap and hold any icon until it wobbles and displays a red minus sign then tap the red minus sign on all active background apps. This does not delete programs, it removes them from memory.
    Once active task bar is empty tap home button to return to home screen. Once on home screen press and hold the power button until the power off slider appears. Slide to power off. Once powered down power back up and see if problem has stopped. A power cycle alone does not remove background apps which would explain your recurring unprompted restarts.
  1. I pad goes blank
    By ghosh99 in forum International iPad Users
    Last Post: 05-04-2012, 01:24 PM
  2. ipad 2 is blank
    By laide in forum iPad Help
    Last Post: 04-10-2012, 08:56 AM
  3. Went Blank on me!!!
    By Georgia boy in forum iPad Help
    Last Post: 10-03-2011, 02:04 AM
  4. Replies: 2
    Last Post: 09-18-2011, 01:06 AM
app is blank on ipad
app store blank
app store blank ipad
blank apps on ipad
blank apps problem
blank screen when in music app on ipad
ipad blank apps
ipad music app blank
music app appearing blank
music app blank
my music app is blank
only problem with ipad is that we can not see the low level apps ipad
