iPAD POWER BUTTON STUCK!
This is a discussion on iPAD POWER BUTTON STUCK! within the iPad Help forums, part of the Apple iPad Discussions category; I recently dropped my when it slid off my lap. Luckily, it was only a span of two feet or so. Unluckily, it landed on ...
07-21-2010 11:22 PM
Is it pressing in and clicking like normal but just not responding?
if so and there is no visible damage like dents most likely your only option is to have it replace. If you have no apple stores around you, you can have it shipped.
another work around would be to set the auto lock in settings to lock the ipad after 1 minute of inactivity. It will then go into sleep mode.
No its literally stuck in there, so the mechanism isn't responsive. .
It's not too much of a problem than an annoyance. But I'm looking for ways to fix it, rather than have a handicapped iPad.
I'm looking for suggestions on how to get it unstuck without having to send it in.
Originally Posted by
semajmik
It may not be something you can fix if it has become loose inside.
I'm not too sure if it's loose or not:
The attributes include:
- no clicking noise
- no movement
- i can't push it in further
I heard someone used a penknife to "unstuck" it . . . and it worked afterward.
I will be attempting that soon . . .
iPad Ninja
Sounds the best solution when there's no motion available.
The first thing I would do is to try and pry the button up to see if it was just stuck in the down position or the mechanism of the switch has actually broken.
Small blade would be best but be aware that scalpel blades do snap..
Sometimes you get lucky.
Any update on this issue?
I just dropped mine today with the same result: the power switch is stuck "in" - I can't press it in at all to turn it off. I don't want to mess with it too much, but I'd love to do a quick fix if you tried and succeeded on yours.
Thanks!
My just Button just got stuck, as well. *that's what she said. Sorry, couldn't help myself. But really, I didn't drop my pad or anything. I've had my iPad for about 9 months. How bout y'all?
Screamjeanne
same issue here. Had my iPad in a nice padded case and dropped it - landed on the corner w/ the power button. all seems to be working fine except the power button won't go on or off. so I have made sure it never loses its charge. I assumed it could be fixed
Fairly easily, but the apple store would only swap it out for $250 ....
Skneip
Everyone heed the advice by Skneip. Without a power button do not let the iPad power off for any reason or you won't be able to power it back up!
Keep it charged until problem is fixed to avoid a shutdown.
- You may not post replies
- You may not edit your posts
Forum Rules
By wasilla in forum iPad General Discussions
Last Post: 07-30-2010, 06:40 AM
By skipper in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 07-18-2010, 04:47 AM
By Dr.Gee in forum iPad Hacking
Last Post: 06-04-2010, 09:06 AM
By Doerwald in forum iPad Help
Last Post: 05-13-2010, 10:15 PM
By Umdterps2002 in forum New Member Introductions - Site Assistance
Last Post: 04-30-2010, 01:28 PM
dropped ipad power button stuck
how to get the power button unstuck
ipad broken power button
ipad button sticking
ipad lock button stuck
ipad on button stuck
ipad on off button stuck
ipad power button not working
my ipad power button is stuck
power button on ipad stuck
power button stuck on ipad
