Comcast E-mail & iPad Problem
This is a discussion on Comcast E-mail & iPad Problem within the iPad Help forums, part of the Apple iPad Discussions category; Hello, I correctly synced my Comcast e-mail and iPad. I usually access my e-mail on my PC, though sometimes on the iPad. When I do ...
Results 1 to 6 of 6
    10169
    Jul 2010
    Hello,
    I correctly synced my Comcast e-mail and iPad. I usually access my e-mail on my PC, though sometimes on the iPad. When I do look at mail on the iPad and then delete the piece of mail using the function on the iPad, it disappears from my iPad as expected. My problem is, that when I return to my PC, the e-mails that I did delete on my iPad are still on my computer in the inbox of my Outlook. Is there a way that, when I delete mail on the iPad, it also gets deleted on my PC (or doesn't even get sent to my PC) and vice versa?
    Thanks.
  2. #2
    iPad Enthusiast!
    9915
    Jul 2010
    93
    When you delete and email from the iPad iPhone or ipod touch, the email is just deleted fr the device, not the server. Let me look around for that.
  3. #3
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    ipad removes from server but your outlook probably is set to save them and already downloaded the messages.
    another thing you can check on your ipad email account under advanced is if the deleted mailbox is set to your ipad or server deleted mailbox. it should be set to server deleted mailbox by default.
  4. #4
    10169
    Jul 2010
    I trieed tampering on both sides.
    I kept my fetch new data selection to push manually which i believe is default. Under my account in the advanced section, i set my deleted messages to be removed after one day. I set "delete from server" to "when removed from inbox" and my server port is 110 (didnt change that). There is also a selection for SSL but I don't think that pertains to my problem. I delete the mail on my iPad but on PC, its still there.
    Any more help will be greatly appreciated thanks.
  5. #5
    10118
    Jul 2010
    14
    I use comcast too, and POP accounts download from the server to the computer or iPad, and then don't care about the email on the server anymore (for the most part).
    If comcast supported IMAP, then you could have everything synced like that. Not sure how else to do it, but I'm sure someone else has ideas.
  6. #6
    iPad Enthusiast!
    9660
    Jul 2010
    CT, USA
    55
    I have comcast as well. What I did to get around all of this was to use a gmail IMAP account. I set my comcast email to forward all email to my gmail account, which works perfectly. It also allows me to send/reply emails using my comcast email address.
Sponsors
  1. E Mail problem
    By Bucknuts in forum iPad General Discussions
    Last Post: 04-12-2011, 11:02 AM
  2. Comcast mail
    By johnny B in forum iPad General Discussions
    Last Post: 11-27-2010, 07:18 AM
  3. Replies: 15
    Last Post: 07-11-2010, 01:05 PM
  4. Ipad mail connect problem
    By galiano in forum iPad Help
    Last Post: 06-16-2010, 12:34 AM
  5. iPad as comcast tech tool?
    By Gazuga6176 in forum Off-Topic
    Last Post: 05-06-2010, 04:09 PM
add comcast email to ipad
adding comcast email to ipad
comcast email for ipad
comcast email ipad
comcast email on ipad
comcast email settings for ipad
comcast email settings ipad
comcast imap
comcast imap ipad
comcast imap settings
comcast imap settings ipad
comcast imap settings iphone
comcast ipad email
comcast mail on ipad
how to sync comcast email with ipad
ipad comcast email
ipad comcast email problems
setting up comcast email on ipad
syncing comcast email to ipad
Tags for this Thread
