Wifi connection problem
This is a discussion on Wifi connection problem within the iPad Help forums, part of the Apple iPad Discussions category; Help! I have been trying to help a friend who has bought a wifi only iPad 3 and cannot connect to his Orange wifi router. ...
Results 1 to 4 of 4
    195888
    Apr 2012
    Help! I have been trying to help a friend who has bought a wifi only iPad 3 and cannot connect to his Orange wifi router. My iPad 3 (3G + wifi) and my iPhone 4 connect with the router as does his HP ePrinter and Kindle, but although his new IPad sees the connection it is not 'ticked' in the wifi settings box. His wife also bought an iPad 2 and this also will not connect. I have tried, rebooting, resetting etc but to no avail. I brought the iPads home and they both connected to my Cable Wii seamlessly. Any advice would be appreciated as I have exhausted my knowledge.
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,229
    Hi there-welcome to the forum!
    I am moving this to our Help section-you will get more attention there.
    Thanks.
    190057
    Apr 2012
    Sydney
    I had and still have a similar problem with my iPhone. I was told by the apple store attendant that it could be a software problem between your device and that problematic wifi router.
    One suggestion, although a real hassle so I have not done it yet, is to do a clean wipe of your friend's new iPad and try to connect with the Orange router as if the device was straight out of the box. If it connects, then it's a software problem that has to do with some of the apps that you have installed in your friend's iPad. If it does not connect, then I think it could be something wrong with the iPad itself.
    I hope that helps a bit.
    195888
    Apr 2012
    Thanks for your help, much appreciated. I will give it a go.
  1. iPad 2 wifi connection drops intermittently....problem solved
    By Appsolutecreations in forum iPad General Discussions
    Last Post: 11-08-2011, 08:46 AM
  2. Problem with wifi connection
    By fribourg in forum iPad Help
    Last Post: 06-13-2011, 08:04 PM
  3. Ipad 2 Wifi Connection Problem
    By King in forum iPad 2 Forum
    Last Post: 04-19-2011, 06:17 AM
  4. Replies: 9
    Last Post: 04-03-2011, 07:29 AM
  5. Replies: 3
ipad 2 drops wifi connection
ipad 3 cannot connect to wifi
ipad 3 help will not connect to wif
ipad 3 losing wifi connection
ipad 3 wifi connection problems
ipad 3 wont connect to wifi
ipad wifi network not ticked
my ipad 3 will not connect to wifi
trouble with ipad3 losing wireless connection
why does my ipad drop wifi connection
why does my iphone lose wifi connection
wifi connectivity problems on ipad for os6
Tags for this Thread
