Cannot Log into iCloud when fixing Calender problem
This is a discussion on Cannot Log into iCloud when fixing Calender problem within the iPad Help forums, part of the Apple iPad Discussions category; Calender plus sign has disappeared on iPad 2, so I tried the fix that was posted in this forum - I went to Settings>iCloud. It ...
Results 1 to 4 of 4
    142256
    Dec 2011
    Canada
    6
    Calender plus sign has disappeared on iPad 2, so I tried the fix that was posted in this forum - I went to Settings>iCloud. It asked me to log in. So I type in my Apple ID username and password. But as soon as I did that, the panel disappeared and nothing happened. So I cannot log into iCloud, therefore I cannot fix the Calender.
    Is this now an iCloud problem for me?? Why can't I log into iCloud?
    Please help!
    579 times
    Dayton, WA
    13,187
    If you have not done so, try restarting or reseting the iPad.
    Open the the iCloud settings again and see if yo can now sign in.
    142256
    Dec 2011
    Canada
    6
    Thanks for the reply ... Sorry I didn't put that in my original post - I have tried everything you have stated but still I have this same problem. Can you think of any other things that will help?
    Thanks again!
    579 times
    Dayton, WA
    13,187
    Does the iCloud account also show up under your Mail, Contacts, Calendars settings. If so try deleting that account, then go back to the iCloud settings and try again. Maybe do a reset before you do the second part.
    Other than that, this might be worth trying.
    Go into Settings > General > Reset, and choose Reset All Settings (NOT the Erase choice right under it). Choose to set up as New iPad when you get to that point.
    It is kind of scary looking, but it will not delete your apps, their contents, nor your accounts. You will have to go back through all your other settings and re-tweak them; things like notifications, sounds, mail, etc.
  1. Can't edit Google Calender on iPad Calender
    By armoredsaint in forum iPad 3 Forum
    Last Post: 03-23-2012, 06:51 AM
  2. How do I sync my ipad calender to my droid calender?
    By pego99 in forum iPad General Discussions
    Last Post: 03-08-2012, 12:48 PM
  3. Thanks for fixing the Share button.
    By twerppoet in forum Official iPadForums.net App Forum
    Last Post: 03-05-2012, 06:12 PM
  4. Why when I sync my iPad calender with google calender do 1 day events become 2?
    By watforddave in forum New Member Introductions - Site Assistance
    Last Post: 02-25-2012, 10:51 PM
  5. iCloud Calender and gmail calender
    By willywonka in forum iPad Help
    Last Post: 10-25-2011, 05:10 AM
how to log into icloud
i cloud login
icloud can't sign in at this time
icloud login
icloud login from iphone
icloud login ipad
icloud login problems
icloud sign in on ipad
icloud you can't sign in at this time
login to icloud from ipad
why can't i sign into icloud
you can't sign in at this time icloud
Tags for this Thread
