os4 upgrade to ipod help about to shoot myself
This is a discussion on os4 upgrade to ipod help about to shoot myself within the iPad Help forums, part of the Apple iPad Discussions category; hi guys any help, i know its ipad not ipod, but im trying to upgrade my os and all im getting is after 15 mins ...
Results 1 to 5 of 5
    iPad Enthusiast!
    6371
    Jun 2010
    Coventry UK
    76
    hi guys any help, i know its ipad not ipod, but im trying to upgrade my os and all im getting is after 15 mins it tells me there is a problem check my conection time out. my net is okay im getting out, have conected to the wire as well as wireless. do it 5 times each the same thing, even tried on another laptop. any ideas. trying to get os4 onto my ipod touch two is starting to get real silly. if its going to be this hard to do his what happens when its time for my ipad upgrade. ha.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    You should be able to just connect to itunes and click the check for updates button.
    iPad Enthusiast!
    6371
    Jun 2010
    Coventry UK
    76
    i did it downloads to end then tells you there was a problem with the downloading, make sure your network setting are right. have downloaded or tried quite a few times and getting now where, i know what it is meant to do but hence the problem
    21743
    Nov 2010
    Melbourne
    I have the same problem, any advice on how to fix this?
    17419
    2 times
    Oct 2010
    Texas
    646
    Check your windows firewall and virus program it does that on mine every time unless I disable them.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
how to ipod os4 update to os5.01?
ipod update
upgrade ipad timeout
