Results 1 to 10 of 12
    47158
    16
    How do i get CCK to work on iPad?
    I have the Camera Connection Kit. When I plug the part that is supposed to allow you to read SD card into either my iPad 2 or my New iPad I get the following message on both iPads: "Accessory Unavailable. The attached accessory uses too much power." What going on with that? What good is the $30.00 accessory if it will not allow me to read an SD card- isn't that what it is SUPPOSED to do? Am I doing it wrong, or not doing something? Any help would be greatly appreciated!!
    iPad Ninja
    49414
    87 times
    North Carolina
    1,962
    Hello - welcome to the forum!
    First, what brand of CCK did you purchase? I own the one that is offered by Apple which has worked fine w/ my iPad 2; cannot comment on the 'new' iPad.
    Second, I would suggest that you 'Restart' and if not successful 'Reset' the iPad - directions HERE, if not familiar w/ the procedure - not sure that these maneuvers will help but will do no harm and are quick.
    Please re-post your results to this thread for further advice if the above does not help - good luck!
    47158
    16
    I'm using the CCK from Apple! Turning off/resetting iPad(s) has no effect but thanks for the reply!
    13576
    801 times
    Aug 2010
    Western NY state (USA)
    9,441
    What size and type of SD card are you using? I just successfully used an 8GB microSDHC card (with an adapter).
    Maybe SD cards are like the USB sticks - you've got to find one that works...?
    185348
    Apr 2012
    Hello iPad lover
    I'm having trouble with the lock rotation button. It is stock in portrait. I press the button but does not change at all. I also tried 2ble press the center button to be able to manage it in a different way, without success. How can I fix it. I want my iPad to be able to rotate again.
    Thanks in advance
    iPad Ninja
    49414
    87 times
    North Carolina
    1,962
    Quote Originally Posted by eloisaveronica View Post
    Hello iPad lover
    Thanks in advance
    Hello Eloisaveronica - welcome to the forum!
    Just a suggestion, i.e. you should have started your own thread rather than post in an unrelated one - just confusing for all and likely will not receive the attention that you deserve - bottom line, hijacking another thread is not good practice -
    But to address your question, I'm assuming that you have changed (in settings) your slide switch (upper right side) from the default of muting the sound to the alternate of fixating your screen orientation - correct? If so, have you returned to settings and set the option to 'sound mute'? Now, there are some other considerations - you'll need to respond first and you may also want to start a new thread w/ your issue, as suggested - good luck!
    185348
    Apr 2012
    I'm soooooo sorry. I'm kind of very new at this. I appologize. And yes I tried all that.
    iPad Ninja
    49414
    87 times
    North Carolina
    1,962
    OK - no problem at all - just that your issue will be lost in this other thread; please start a new thread of your own and describe your problem and the steps that you have taken to try a correction; if not already done, you may try to 'Restart' and if not helpful 'Reset' your iPad - directions HERE, if not familiar w/ the procedure - good luck and hope to see you posting your own thread -
    47158
    16
    Update on getting CCK to work on the iPad. I talked to Apple support yesterday; they suggested I take CCK somewhere & try it on another iPad, so I went to my AT&T store. We hooked up my CCK, using my thumb drive & my USB card- neither one would bring up any pix on their iPad. So we hooked up AT&T tech's iPhone up to my iPad- her pix came up on my iPad! I hooked up MY iPhone to MY iPad & got pix. SOOOO, I can upload pix from iPhone to iPad using CCK just fine, but when I try to upload pix from either USB or thumb drive it will not work!! I formatted a thumb drive, moved a pic over from my pc to newly formatted thumb drive then hooked up thumb drive to iPad via CCK-no go! For some reason, it will not upload JPG pic from my pc. I'm open to any suggestions!!
    129720
    18 times
    Nov 2011
    474
    Thumb drives placed into the CCK does not work. The ipad does not have enough power for the thumb drive.
    The CCK USB adapter is for powered camera connection only.
  1. My iPad 2 app won't work!
    By Rosalind in forum iPad Help
    Last Post: 03-14-2012, 02:09 PM
  2. My SIM looks a little different.. will it work in iPad?
    By cjblack999 in forum iPad Carriers
    Last Post: 11-27-2011, 01:41 PM
  3. why wont my work website wont work on ipad2
    By ipadguy311 in forum iPad Help
    Last Post: 07-05-2011, 03:59 PM
  4. Usa ipad 3G sim will it work in uk
    By Michelle Scotland in forum New Member Introductions - Site Assistance
    Last Post: 04-04-2011, 05:25 AM
  5. I work for Ipad ??
    By IpadOne in forum iWork Forum
    Last Post: 03-12-2010, 10:40 AM
attached accessory too much power
camera connection kit requires too much power
cck ipad
connected usb requires too much power fix
ipad camera connection kit usb device requires too much power
ipad cck
ipad cck with flash drive?
ipad the connected usb device requires too much power fix
the attached accessory uses too much power
the attached accessory uses too much power ipad
the attached accessory uses too much power ipad 2
why does my ipad cck not work
