IPAD VPN will not connect
This is a discussion on IPAD VPN will not connect within the iPad Help forums, part of the Apple iPad Discussions category; Hello to all, I have a 64 GB 3G Ipad, with a Telus account. I have a serious problem making my VPN works. I also ...
Results 1 to 2 of 2
    9494
    Jul 2010
    Montreal
    Hello to all,
    I have a 64 GB 3G Ipad, with a Telus account. I have a serious problem making my VPN works. I also have an Ipod Touch second generation and the VPN works perfectly on it.
    So I use the same settings on my Ipad as the Ipod:
    PPTP
    - same server
    - same account
    - RSA SecuriID OFF (i try to make it OFF on the Ipad and save the settings and when I look back, it goes back to ON)
    - encryption level AUTO
    - Send all traffic ON
    - Proxy OFF
    My Ipod has only WIFI and once I connect to my working place or home WIFI, I can connect to VPN without any problem. However, the Ipad cannot connect to VPN whatsoever, with WIFI on or with Telus 3G on. Here is the message:
    "A connection could not be established to the PPP server. Try reconnecting. If the problem continues, verify your settings and contact your Administrator."
    I contacted Telus and bought their VPN bundle and it does not change anything. Anyway, when I am on WIFI at work, VPN should connect if I use the correct settings. So I am at loss here. Can anyone help me please?
    9494
    Jul 2010
    Montreal
    I was able to make it work. Apple tech support told me to reset my network settings. I did that and configured a new VPN connection and everything went well.
  1. Can iPad connect to iTunes server?
    By magoomba in forum iPad Help
    Last Post: 04-28-2012, 05:20 AM
  2. Cannot connect to iTunes on iPad
    By vintageb3 in forum iPad Help
    Last Post: 06-21-2010, 09:03 PM
  3. Ipad mail connect problem
    By galiano in forum iPad Help
    Last Post: 06-16-2010, 12:34 AM
  4. iPad will only connect via DMZ
    By Hank3rd in forum iPad Help
    Last Post: 06-15-2010, 11:33 PM
  5. How to connect and use an USB external HD to the iPad
    By Ripplinghurst in forum iPad Hacking
    Last Post: 05-22-2010, 07:11 PM
a connection could not be established to the ppp server
a connection could not be established to the ppp server ipad
a connection could not be established to the ppp server. try reconnecting
connection could not be established to ppp server
ipad cannot connect to vpn
ipad vpn not connecting
vpn connection a connection could not be established to the ppp server
vpn connection a connection could not be established to the ppp server.
vpn not connected ipad
vpn not connecting ipad
vpn not working on ipad
vpn stopped working ipad
