need to respring after power on
This is a discussion on need to respring after power on within the iPad Help forums, part of the Apple iPad Discussions category; Hi and good evening all, had my Ipad 64gb 3g for 2 months, jailbroke by using 'spirit', everything works fine until yesterday, installed 'fring' in ...
Results 1 to 8 of 8
    9444
    Jul 2010
    17
    Hi and good evening all, had my Ipad 64gb 3g for 2 months, jailbroke by using 'spirit', everything works fine until yesterday, installed 'fring' in Itune and 'mywi' from sinfuliphonerepo, 3-4hours later, my Ipad acting weired,
    1) turn ipad power back on, screen appears
    the red circle area won't sense my finger at all.
    2) after type in passcodes
    my wallpaper disappear, just black in background, also my 'contact' icon and 'maps' icon become totally white sqare box.
    3) about two inches above from home bottom, screen won't detect my finger movements, also if small window pops out in the center of the screen "ok" or "cancel", either one i press, won't responds at all, have to press home bottom.
    4) but when i press on respring bottom from:
    the screen goes off with "restart springboad", then things back to normal, sense correctly when my finger on the screen, but cannot fully power off, has to off in sleep mode, otherwise need to respring again and again in order to get it fiction right. Any experts know what should i do????? please help, thanks in advance
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    This is normal
    The jailbreak apps were made for iPhone not iPad. After installing certain apps this will happen after every reboot and you will just have to respring the springboard. At this point its no something that can be fixed short of a full restore.
    Also notice you should be able to pull up sbsettings and respring before entering your passcode at the lock screen. And dont spend any time organizing your apps because once you reboot and it goes into the ipod mod, ipod mode only has 4 X 4 icons on each page and it will scatter all your apps to different pages.
    9444
    Jul 2010
    17
    thanks for reply, you meant full restore from itune or spirit?
    9444
    Jul 2010
    17
    Quote Originally Posted by MikesTooLz View Post
    This is normal
    @mike, you are absolutly right, it is pain in the neck for me to respring every time, if i want to full restore, should i do it in itune or spirit?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    You would do it in itunes and it will delete everything from your iPad and remove the jailbreak.
    9062
    Jul 2010
    11
    Better restoring your iPad to factory settings, this removes all the existing data (music/apps/vids etc) and jailbreak from your iDevice. When you jailbreak your iDevice, make sure you do a little research before installing 3rd party apps. Not all apps on Cydia works with iPad.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by BluAzn View Post
    Its pretty much something you have to live with if you jailbreak. one of the best and widely used jailbreak apps SBSettings will cause this after being installed.
    211285
    May 2012
    Dubai
    9
    Same problem
    Hi i am having same problems with my ipad3...any solutions it's very annoying to respring all the time after reboot n further all icons/folders are unorganized..
    Please help
  1. Respring my iPad
    By avivit02 in forum International iPad Users
    Last Post: 07-24-2010, 02:52 PM
  2. Power Up Problems
    By jrd042 in forum iPad Help
    Last Post: 07-14-2010, 05:12 AM
  3. How does the 10W Power Adapter work
    By vickypt in forum iPad Help
    Last Post: 06-27-2010, 02:41 AM
  4. Power Tests
    By Seadog in forum iPad General Discussions
    Last Post: 04-06-2010, 10:25 PM
  5. Different Power adapters?
    By raylock in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-31-2010, 09:10 AM
how to respring ipad
how to respring ipad 2
how to respring ipad 2 without jailbreak
how to respring ipad without jailbreak
how to respring ipad2
how to respring without jailbreak
ipad icon scatter after reboot
ipad icons become small
ipad respring
respring after each boot ipad icons
respring ipad
respring ipad 2
Tags for this Thread
