Ipad 3 remembering wifi network passwords
This is a discussion on Ipad 3 remembering wifi network passwords within the iPad Help forums, part of the Apple iPad Discussions category; It is off. Comment below says that known networks will be joined automatically. I have two networks, one on each floor, one is joined automatically, ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    233886
    Aug 2012
    6
    It is off. Comment below says that known networks will be joined automatically. I have two networks, one on each floor, one is joined automatically, the other i need tomretype the pwd every time
  3. #12
    161350
    Feb 2012
    52
    Quote Originally Posted by sjpriv
    Try turning it "on". The next time you enter the correct PW, it should be saved and you should not have to enter it again. If that doesn't work, better have a "genius" at the Apple Store take a look at it.
  4. #13
    85546
    575 times
    Aug 2011
    Edmonton AB Canada
    9,845
    If you have one network that doesn't function properly, tell the ipad to forget it, then allow it to find it again.
    I use many networks in my travels and most of them work perfectly without needing to input passwords. I would reset network settings only as a last resort.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
  5. #14
    233886
    Aug 2012
    6
    So should the "ask to join" be on or off ? I have two wifi's at home and switch between them all the time. Pls help
  6. #15
    161350
    Feb 2012
    52
    I leave mine "ON" because I wish to be reminded when new network appears. This should not impact your iPad's ability to find and connect to a network.
  7. #16
    233886
    Aug 2012
    6
    Yes, has made no difference. Could it be something relevant to the linksys rather than the ipad
  8. #17
    iPad Wizard
    49745
    440 times
    6,973
    I have two wifi networks at home, too, and both my iPad 1 and 2 have no prob remembering their passwords. The same goes for trusted wifi networks that I've used previously. It doesn't matter if months have gone by without my having used a network; the iPads still remember the passwords.
    The only diff would be at a place like my work, where they create a new wifi password daily.
  9. #18
    233886
    Aug 2012
    6
    yes i have and it has made no difference.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Remembering passwords on ipad 2
    By rebecca.lucas in forum iPad 2 Forum
    Last Post: 02-10-2012, 09:31 PM
  3. Replies: 3
    Last Post: 11-09-2011, 07:32 PM
  4. iPad not remembering home network security key
    By villager66 in forum iPad Help
    Last Post: 07-19-2011, 01:32 PM
  5. USING ipad 2 ON A 3G WIFI network
    By FP633 in forum iPad Help
    Last Post: 06-17-2011, 06:50 AM
how do i get my ipad to remember my wifi password
how to get ipad to remember wifi
how to get ipad to remember wifi network
how to make ipad remember network passwords
how to save known network passwords ipad
ipad 3 problem with remembering wifi password
ipad won't remember wifi password
remember wifi password ipad
