Trouble logging in with Wi-Fi at Hotel
This is a discussion on Trouble logging in with Wi-Fi at Hotel within the iPad Help forums, part of the Apple iPad Discussions category; I am at a hotel trying to log in with Wi-Fi. I go to Settings/Wi-Fi and I can see the hotel network and it is ...
I am at a hotel trying to log in with Wi-Fi. I go to Settings/Wi-Fi and I can see the hotel network and it is checked, but the log-in screen that I need to log into the hotel wi-fi does not always come up to allow me to log in. Sometimes it does pop up and sometimes it does not.
thanks
07-12-2010 09:35 AM
iPad Junkie!
Originally Posted by
dcotsman
thanks
Its most likely the hotels wifi. I find they are weak, intermittent, hit and miss.
Thanks, the only thing is, we have 4 Ipod touch/Ipads between us and 3 of the 4 are able to pop-up the hotel log-in screen consistently.
iPad Enthusiast!
dcotsman
I've observed the same issue logging in from hotels. Seems the iPad takes a bit longer to grab the hotel's wifi signal, and flip to a login screen. Give it 10 or 15 seconds - if that doesn't work, open up Safari and go to google.com and see if it redirects. That's worked for me in the past.
Does that help?
iPhone 3G 8GB (black) / iPad 16GB wifi / Apple folio case => tucked into a Timbuk2 Freestyle Messenger
~Follow me on Twitter: @iDharma~
Thanks, but trying to google still does not bring up log-in screen for this Ipad all the time.
Yup, it's likely the hotel Wi-Fi being flakey or the signal is intermittent where you are. Unfortunately, hotels walls (pipes, elevator and other metal) do a lot to interfere with Wi-Fi.
Try going to the hotel lounge or other area where you are confident there should be very good signal and try again. If it's still flakey, you might try telling the front desk.
I hope this helps.
Woowoomac.com - Learn something new, useful and fun about your iPad, Mac and iPhone.
I'm posting this here in case someone else has the same issue later. You don't have to log in with the same machine(maybe), my PSP and PS3 has exceptional trouble with log in screens.
Depending on what internet service they have you could try how I do with Ethostream's wifi service.
/CentralAuth/auth/index.php?ip=______&mac=_______&iface=______&sitei d=________&at=___&
If the address shows something similar to this you can use any device to log in your device. You just have to fill in the blanks and go to the page and log in like normal. and viola device should be activated.
This is definitely something Apple could improve. I travel with an iPad and a Blackberry phone. The iPad finds the available WiFi signals and shows which ones are locked, etc, but even if the correct one is obvious and free to use, you still have to tell it to log in each time. Sometimes when you select the correct one and have its WiFi password ready to enter, you instead get a screenful of boxes to fill in.
I have to say, you get none of these problems with the BB. As soon as it finds a free WiFi spot, it just logs in automatically and starts working. You don't even know it has done it. Much better!
DM51
- You may not post replies
- You may not edit your posts
Forum Rules
By GordonD in forum iPad Help
Last Post: 02-15-2011, 09:29 PM
By Matth3w in forum iPad Apps
Last Post: 08-14-2010, 12:36 AM
By Jazzephaye in forum iPad Games
Last Post: 07-11-2010, 06:57 PM
By rmcsteve in forum iPad Accessories
Last Post: 06-05-2010, 05:43 PM
appletv ethostream
connect ps3 to ethostream
ethostream
ethostream free login
ethostream iphone
ethostream login
ethostream login page
ethostream mac
ethostream radisson
ethostream troubleshooting
ethostream wifi
hotel log in with ethostream
hotel password screen will not show up
hotel wifi login
how to log on to ethostream
how to login ethostream free
ipad wifi login popup
iphone wifi login popup
login free wifi wont pop up
weak hotel wifi
