How do I get rid of the sound effects icon in the middle
This is a discussion on How do I get rid of the sound effects icon in the middle within the iPad Help forums, part of the Apple iPad Discussions category; Can anyone help me get rid of the sound effects icon that is in the middleof my screen? This little old lady is getting exasperated ...
Results 1 to 7 of 7
    177454
    Mar 2012
    Can anyone help me get rid of the sound effects icon that is in the middleof my screen? This little old lady is getting exasperated looking at the annoying little thing and it's interfering with my games!!!
    48665
    948 times
    Brisbane, Australia
    23,488
    Hi and welcome to the Forum!
    We've had reports of this happening by other members try a Restart/Reset and see how you go.
    Press and hold the power off button, the one at the top right. You will see a slide appear to power off, slide this and the screen will go dark and a Whirly will appear. When the Whirly disappears your iPad is now off. Press the power button again until the Apple logo appears, this will take a few seconds and your iPad will restart. You should restart your iPad occasionally also as it will keep it running well. Now see if it is operating.
    Hold the power off button and the home button simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
    Let us know if this gets rid of it.
    Please do not post twice on an issue, as well as being against our Rules it leads to confusion, I have deleted your other thread and shall move this to our Help Section where it will receive a better response.
    iOS5 Tips and Tricks
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    185196
    Apr 2012
    This did not work for me. The sound effects icon is still here after following these instructions.
    48665
    948 times
    Brisbane, Australia
    23,488
    Quote Originally Posted by Diva Designs
    Have you had your iPad connected to either a Bluetooth keyboard or headphones at all? If you pull the headphones out without stopping the music first this can lead to sound problems. Sound can also be turned off by some keyboards.
    196959
    Apr 2012
    Boston, MA
    I'm having the same problem. Don't do anything to scratch or dent the iPad, because it'll void the warrantee.
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    If your volume rocker switch is jammed the sound icon stays on the screen.
    Try moving volume up and down, make sure the switch is responding properly and returning to its neutral position when released.
    58038
    May 2011
    Pennsylvania
    61
    try turning the mute button on and off a few times. I had mind stuck and this solved my problem
  1. Sound effects
    By shawren in forum Forum Rules, Help and Info
    Last Post: 11-07-2012, 01:25 PM
  2. iPad 2 / iPhone 4 as a Vocal effects loop
    By alunwill in forum iPad Help
    Last Post: 07-12-2011, 08:12 AM
  3. antenna positioning effects on the ipad, ala iphone4
    By monkeyboy in forum iPad General Discussions
    Last Post: 07-04-2010, 11:13 PM
  4. Hello from the middle of nowhere
    By siliconrane in forum New Member Introductions - Site Assistance
    Last Post: 05-31-2010, 10:01 PM
how do i get rid of ipad sound effects mute
how to get rid of sound efects pictire ipod
how to get rid of sound effects icon on ipad
how to get volume icon off ipad
i have a sign in the middle of my screen can`t get rid of says no volume i do have sound
ipad sound effects icon
what if your ipod keeps showing sound effects
why does ,y sound effects sign keep coming up on my ipad
