iPad 2 is Beeping While Charging
This is a discussion on iPad 2 is Beeping While Charging within the iPad Help forums, part of the Apple iPad Discussions category; When charging my iPad 2, I get this constant beeping sound. The battery notification {at the top} blinks as if there's a bad connection. I've ...
Results 1 to 2 of 2
    151905
    Jan 2012
    NYC
    7
    Question iPad 2 is Beeping While Charging
    When charging my iPad 2, I get this constant beeping sound. The battery notification {at the top} blinks as if there's a bad connection. I've changed the usb cord, I've plugged the ipad into different outlets around the house, but I still get that beeping. I'm not able to charge my iPad at this point. What the heck is going on and how can I fix it? Thank you!
    145924
    Jan 2012
    Mid-Michigan
    13
    I've had similar experiences. I have two sync cables I bought over eBay. The first works fine, although I have had to glue the cable back into the USB plug end as the cable had pulled loose (it still works however). The second appears to be of better quality, but it will behave as your does when using the wall charger. It will charge and sync properly when connected to the USB port on my Macbook Pro. I am perplexed.
  1. Being driven insane by my ipad beeping
    By Himynameisrhys in forum iPad General Discussions
    Last Post: 08-03-2012, 07:57 AM
  2. Why does the ipad keep beeping
    By cher3329 in forum iPad 2 Forum
    Last Post: 02-19-2012, 08:56 PM
  3. Beeping iPad
    By BarbaraH in forum New Member Introductions - Site Assistance
    Last Post: 08-24-2011, 03:44 PM
  4. Replies: 7
i pad keeps beeping when plugged in
ipad beep when charging
ipad beeping when charging
ipad beeping while charging
ipad beeps when charging
ipad beeps while charging
ipad charger keeps beeping
ipad keeps beeping
ipad keeps beeping when charging
ipad noise when charging
why does iphone 5 beep while charging
why does my ipad beep while charging
