WiFi connectivity: WEP vs WAP (and neither works)
This is a discussion on WiFi connectivity: WEP vs WAP (and neither works) within the iPad Help forums, part of the Apple iPad Discussions category; First off, the only WiFi I have is Verizon FIOS. I have it at home, at work, and at my boss's house. I haven't tried ...
Results 1 to 9 of 9
    3632
    May 2010
    Land O Lakes, FL
    28
    First off, the only WiFi I have is Verizon FIOS. I have it at home, at work, and at my boss's house. I haven't tried hotspots, so I'm not sure how that reacts.
    The problem is the iPad won't remember the password for the WiFi. Worse, now it won't even connect. Originally, the router was set up for WEP; Apple Support said they were having problems with Verizon, change the router to WAP, which was done. But now it's worse than it was with WEP. The only GOOD thing is that the WAP password is easier to remember than the WEP .
    This is happening on all 3 of the iPads we're using. It's gotten so bad (with the pop-ups), I had to shut off WiFi and work off 3g. Apple Support doesn't seem to have the answer, so I thought the good people here might be able to offer a work-around?
    iPad Master!
    2051
    3 times
    Apr 2010
    home
    1,352
    Have you tried without WEP or WAP? I use Mac address filtering and have zero problems.... but then again I'm not on Verizon...
    Bremen Cole
    iPad 1st Gen 16G
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by Bremen View Post
    Thats a bad idea as far as security goes. Would only take a minute or two to gain access to your network with only MAC filtering on.
    It may be the access points that Verizon is providing that are doing something strange. You may want to look into turning off your Verizon wifi and purchasing a new wifi router or access point for about $30
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    I know Mac is crap security but then my neighbours ain't that bright
    That said wep can also be cracked if they really want to.
    Security is only relative and I wouldn't trust any of mine........
    3632
    May 2010
    Land O Lakes, FL
    28
    Quote Originally Posted by MikesTooLz View Post
    Because I'm using FIOS (a fiber optic system), I don't think I have the option of bypassing Verizon's router. The operational phrase is "I don't think": I'll have to call them and ask, I guess.
    iPad Master!
    2051
    3 times
    Apr 2010
    home
    1,352
    Quote Originally Posted by Hasty View Post
    So true... Any security can easily be beaten by those who know how. I went to Mac filtering after I realized the School district I was working for used it, with great success. It was their only security for 12 campuses and over 40 WIFI access points.... only 1 time in the 8 years I was there was it breached (they knew by logs and such) and they quickly cut that one off.....
    I think it would be safe to say 95% of people don't even know what a Mac address is..... much less a spoofer.....
    Bremen Cole
    iPad 1st Gen 16G
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by LeeB View Post
    What you do is leave your Verizon Router in place for FIOS.
    Turn WIFI on the Verizon router off.
    Connect the new router to one of the eithernet cable ports on the Verizon router. Example: computer port 1 on new router would connect to computer port 1 on verizon router and they would then communicate and share internet.
    So your new wifi router then gets internet access from your Vernon router and allows your wireless devices to connect with this new, better wifi router.
    7971
    Jun 2010
    29
    I tried to turn off wifi on my verizon fios actiontec router by plugging in my laptop to the router by wire, typing 192.168.1.1 which got me into the verizon site. Username: admin and tried password and password1 but both failed. I also noticed that I could not manually type in the password as every keystroke I made it was like 4 or 5 characters were being entered.
    Anyway I simply copied and pasted the password into the password field but all I got was fail message. Is it possible that the verizon technician who installed it changed the password?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    yeah the default username should be admin and the default password should be password. However the tech may have set it to something else like password1 or admin.
    try the usernam/passwrod admin/admin
    if the router they provided is a D-Link you can try the username admin and leave the password blank.
    If all else fails you can always hold the reset button on the router and reset the router to factory settings and the password will go back to password.
  1. Connectivity issues
    By TheMitz in forum iPad Help
    Last Post: 04-09-2011, 10:24 AM
  2. Ipad 3Gb+Wifi can works without microSIM?
    By jacppe in forum iPad General Discussions
    Last Post: 08-16-2010, 01:23 PM
  3. Internet Connectivity
    By Louisg in forum iPad Help
    Last Post: 06-29-2010, 01:42 AM
  4. Can someone explain how itunes works?
    By Awesome in forum iPad General Discussions
    Last Post: 05-14-2010, 09:06 PM
  5. Verizon iPad still in the works
    By iDan in forum Apple iPad News
    Last Post: 02-11-2010, 10:38 AM
best wap ipad
can ipad support wep
configuring ipad wap
does ipad support wap wireless
ipad wap
ipad wap settings
ipad4 dlink router
using wap on ipad
wap .in
wap ipad
wep .in
wep vs wap
