photo sync problem
This is a discussion on photo sync problem within the iPad Help forums, part of the Apple iPad Discussions category; Hi I got my ipad yesterday and am having problems syncing photo's. yesterday I created a folder on my pc and put 4 photo's in. ...
Results 1 to 3 of 3
    9096
    Jul 2010
    Basingstoke
    photo sync problem
    Went to the photo tab in itunes
    selected said folder
    clicked apply
    and then sync
    photo's on ipad - great!
    I then played somemore, downloaded some apps etc and today I added some more photo's to the folder and went to do the above it is now giving me a pop up message saying that it will remove all the apps from my ipad.
    I can see all the apps in itunes when the ipad is not connected
    help please!!! What am I missing?
    Steph
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    When your iPad is hooked up to your computer and iTunes is running, is there a checkmark under the Apps tab? If it somehow got un-checked by accident, it will remove the apps from your iPad, but all you have to do is check that box and all of the apps you want, and they will be sync'ed back to your iPad. Clear as mud?
    9096
    Jul 2010
    Basingstoke
    Not sure about that will check.
    I got very cross with it and in the end clicked ok to removing the apps as I knew worse case they were all in iTunes and it worked! Photos on the ipad and all apps still thereto!
    Weill still check settings you recommend though. Thanks for the help
  1. Photo/Image Saving Problem
    By krmiller01 in forum iPad Help
    Last Post: 11-24-2011, 06:52 AM
  2. iTunes sync problem.
    By epb in forum iPad Help
    Last Post: 11-05-2011, 08:00 PM
  3. iPad Photo Question/Problem
    By fairoasis in forum iPad Help
    Last Post: 09-25-2010, 06:09 PM
  4. Photo Sync :(
    By !SUPER! in forum iPad Help
    Last Post: 07-06-2010, 12:34 AM
  5. Sync Problem
    By Snapp in forum iPad Help
    Last Post: 05-27-2010, 08:23 PM
ipad 3 photo sync problem
ipad 4 photo sync problems
ipad photo issues
ipad photo problems
ipad photo sync problem
ipad photo sync problems
itunes photo sync problem
photo sync notworking on pc
