So, I have the first IPad which has met all of my needs thus far. Lately it's been just blanking out of whatever is on my screen . It's annoying. It's a 32GB.
. Please help! Thanks
This is a discussion on First IPad within the iPad Help forums, part of the Apple iPad Discussions category; So, I have the first IPad which has met all of my needs thus far. Lately it's been just blanking out of whatever is on ...
If you have not done so, give these quick fixes a try and see if they help.
