Replacement board that the Power Flex Cable plugs into
This is a discussion on Replacement board that the Power Flex Cable plugs into within the iPad Help forums, part of the Apple iPad Discussions category; What is the name of the board that the Power Flex Cable plugs into and can it be replaced? I think I broke the socket ...
Results 1 to 4 of 4
    173510
    Mar 2012
    USA
    What is the name of the board that the Power Flex Cable plugs into and can it be replaced? I think I broke the socket on this board trying to remove the old flex cable with all that tape around it. The copper that makes a rectangle around the socket has a small gap in the copper. I have ordered a new power flex cable and wont be able to test it until it arrives, but I have a feeling I'm going to need to replace that board.
    Here is a picture of the socket and the board that will need to be replaced (not sure what the name of the board is though):
    Replacement board that the Power Flex Cable plugs into-ipad-2-disassembled-2.jpg
    Mike
    173510
    Mar 2012
    USA
    Somehow I forgot to mention this, but this is a iPad 2.
    217197
    Jun 2012
    Hi Mike, hiya doin. Hope you can guide me through. I broke my iPad 2s power flex cable and I also need replace it. I was looking for tutorials online but there seems to be no videos about the procedure. I ordered a replacement cable but I don't want to be in the same situation. Would you tell me what you did wrong?
    I would really appreciate anything you can suggest to prevent me from breaking the circuit board. Have a great day!
    216911
    Jun 2012
    12
    It's called the WiFi Sensor PCB. It has the accelerometers and connection for your power, volume, rear camera and WiFi sensor (though not the WiFi antennae oddly enough).
  1. go flex+3g router
    By neil4374 in forum iPad General Discussions
    Last Post: 12-12-2011, 10:33 PM
  2. Go Flex satellite/internet
    By neil4374 in forum iPad Help
    Last Post: 11-27-2011, 10:13 PM
  3. iPad 2 USB cable and power adapter
    By innkuang in forum iPad 2 Forum
    Last Post: 10-20-2011, 02:21 PM
  4. Longest IPad Power / Sync Cable
    By macguy79 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-15-2011, 04:20 PM
  5. Phrase Board - Communication board when unable to speak
    By momvetty in forum iPad App Announcements
    Last Post: 07-09-2010, 08:23 AM
apple ipad power on/off volume control flex cable
cambiar flex power ipad 2
how to change ipad 2 power flexicable
how to replace ipad 2 power flex cable
how to replace power flex cable ipad 2
ipad 2 flex cable
ipad 2 power flex cable replacement
ipad 2 power flex cable replacement diagram
ipad2 diagram of flexes
power flex cable ipad 2 gen
