Help with ipad
This is a discussion on Help with ipad within the iPad Help forums, part of the Apple iPad Discussions category; Hi. I am new to this...I installed the update at the App Store yesterday and now nothing works. I get a black screen where the ...
Results 1 to 5 of 5
Thread: Help with ipad
    171205
    Mar 2012
    Help with ipad
    Hi. I am new to this...I installed the update at the App Store yesterday and now nothing works. I get a black screen where the tower should be with blue edges..I removed the ame from ipad and tried to reinstall but same thing happens...Anyone else have this happen and how do I fix it?
    48665
    479 times
    Brisbane, Australia
    19,126
    Quote Originally Posted by Casey123
    So you have deleted the app and then redownloaded it? The only thing I can think to try here is a reset of your iPad
    Hold the power off button, the button at the top of your ipad and the home button, round one in the middle at bottom, simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start. I hope this works for you, if not it just may be something wrong with the update and getting in touch with the Developer may be the best step. Let us know how you go.
    iPad 2 64gb 3G
    48665
    479 times
    Brisbane, Australia
    19,126
    Thanks leelai.
    If I reset the iPad will i lose everything like my contacts, etc?
    No, nothing will change, it's more or less the same as rebooting a computer. So nothing to worry about.
    iPad 2 64gb 3G
    171205
    Mar 2012
    Hey
    Rebooted iPad but still not working..seems other apps are acting differently sometimes as well. May be a problem with iPad??
    I have the first generation.
    48665
    479 times
    Brisbane, Australia
    19,126
    Hey
    Hi Casey, I've given you your own thread rather than trying to deal with this in the games thread.
    What's happening with your other apps? It just may be a problem with your iPad.
    Let me know everything that is strange
    iPad 2 64gb 3G
how to reset ipad first generation
