iPad Camera not working
This is a discussion on iPad Camera not working within the iPad Help forums, part of the Apple iPad Discussions category; The camera on my iPad is not working. When I open it it looks like it is taking pictures constantly. But no pictures are actually ...
Results 1 to 6 of 6
    169253
    Feb 2012
    Mapleton,Il
    The camera on my iPad is not working. When I open it it looks like it is taking pictures constantly. But no pictures are actually being taken. There are colored fuzzy lines down the screen after it tries to take a picture. Any help anyone could give to help would be appreciated.
    168527
    7 times
    Feb 2012
    NZ
    143
    These may sound like silly questions, but it's best to get the basics checked.
    Do you have a cover on your iPad that is compatible. Ie, that isn't covering the lens.
    Do you have the same issues when you change to face view?
    Do you have the same issue if trying to video?
    Have you tried using the camera inside an app, and does it work then?
    169253
    Feb 2012
    Mapleton,Il
    The fuzzy lines show up with and without the cover on the iPad. The video and the camera both show the same lines and it looks like it keeps taking pictures, but isn't really. When I turn the camera to face view, it works just fine. The camera will not work inside an app. Thanks for any help given.
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Hello Athomas and welcome to the forum!
    I also will suggest a few more 'basic' steps (if not already tried?) - when an App is misbehaving a 'force shut' may restore its function, i.e. open the multi-taskbar by double tapping the home button or by using multi-finger gesturing; find the Camera icon; press & hold until all jiggle; press the minus sign; return to the home screen and try again.
    If the above does not correct the problem, then 'Restart' and if not effective 'Reset' the iPad - directions HERE - good luck and please post back to this thread if the app/camera is still not working correctly!
    169253
    Feb 2012
    Mapleton,Il
    I tried the force shut down and restarting the iPad and the camera is still behaving in the way I mentioned above.
    3851
    19 times
    May 2010
    Miami, FL
    2,366
    sounds like a faulty camera to me.
    take it in to the apple store while its still under the 1 year warranty so they can replace it.
  1. Camera not working!
    By tomster in forum iPad 2 Forum
    Last Post: 05-03-2013, 06:26 AM
  2. Ipad front camera not working
    By jash1120 in forum iPad 2 Forum
    Last Post: 02-17-2012, 09:23 PM
  3. Camera iPad 2 not working after update to iOS5?
    By Kazza15 in forum iPad 2 Forum
    Last Post: 02-05-2012, 05:31 AM
  4. Camera not working!!!!
    By fbbdab in forum iPad 2 Forum
    Last Post: 08-08-2011, 03:35 PM
  5. Camera still not working
    By Ronfromcocoa in forum iPad Help
    Last Post: 07-09-2011, 09:39 PM
ipad camera not working
my camera isnt working on my ipad
my camera on my ipad isn't working
my ipad camera is not working
the camera on my ipad isn't working
video not working on camera
why isn't my ipad camera working
why isnt my camera working on my ipad
