iPad sound
This is a discussion on iPad sound within the iPad Help forums, part of the Apple iPad Discussions category; My iPad isn't playing sound while I am typing or in a game app. My sound is all the way up, and it works when ...
Results 1 to 10 of 15
Like Tree3Likes
Thread: iPad sound
    168008
    Feb 2012
    Pennsylvania
    iPad sound
    My iPad isn't playing sound while I am typing or in a game app. My sound is all the way up, and it works when I play music or a video. Please help!!
    48077
    10 times
    Illinois
    488
    A restart/reset usually does the trick for me when this happens.
    iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    97693
    501 times
    Sep 2011
    Michigan. USA
    15,282
    Hi Stupidmuggles (I feel bad calling you that!)
    Aside from the good device that idave23 gave you...have you tried to check your sound settings? If you haven't yet, go to ipad settings/sounds/keyboard clicks. Check to see if key board clicks are turned on.
    Regarding the sound in your games--go to the games that you play and see if there is an option for music to be turned on/off. Give that a try as well. Post back if it doesn't help you.
    Also: Welcome to the iPadForum! This forum is loaded with invaluable information which contain topics including: General Discussion of the iPad, iPad Operating System, iPad App Store, Accessories, and Ipad for Business and Education.
    The iPadForum also includes a Regional Ipad Group for international users across the world. This is a wonderful area to "find" members from your own country. See here:Regional iPad Groups
    If you have not already done so, please take a moment to download the iPad Manual User Guide iOS 5. This is extremely helpful if you are new to the iPad world.
    http://manuals.info.apple.com/en_US/ipad_user_guide.pdf
    Finally, please take the time to read the Forum Rules:
    Best Wishes and Enjoy!
    goofy8275 likes this.
    579 times
    Dayton, WA
    13,187
    Sounds like Mute. This can be turned on/off either using the slide switch next to to the volume buttons, or in the multitask bar. See below link for info on how to check you settings for the side switch.
    iPad: Understanding the side switch
    Contrary to common sense, Mute does not stop all iPad sounds. It only stops system sounds like; key clicks, alerts, ringing, etc. Music, video, and most game audio will are not affected. It's mostly about stopping the iPad from making awkward noises at meetings, the theater, or during grandpa's fishing stories.
    That said, my system sounds did stop the other day, and Mute was not on. A restart fixed it right up.
    97693
    501 times
    Sep 2011
    Michigan. USA
    15,282
    I didn't know that about the mute only muted certain things. I thought it was an all or none.
    Well I have learned another new tip from you, twerppoet. Thank you!
    579 times
    Dayton, WA
    13,187
    No problem.
    A few other things about sound settings, just because.
    To shut off all sounds hold the volume down button for a couple seconds. It goes to zero almost immediately. Takes longer to turn it back up.
    However, this may not shut of system sounds. If you've got Change with Buttons turned off in the Sounds settings ,the system sounds will still be whatever that volume is set to. In that case you'll need to mute and turn the volume off to eliminate all possible sounds.
    And for those who don't know, the iPad keeps separate volume levels for the speaker and headphone jack. Don't expect turning the volume down/off on one to affect the other.
    skimonkey likes this.
    168008
    Feb 2012
    Pennsylvania
    When you reset it, will it erase all of my apps, or music?
    579 times
    Dayton, WA
    13,187
    A reset will not delete anything.
    191369
    Apr 2012
    All my settings are turned ON...I don't hear the clicking sound BUT I'm able to play YouTube and watch movies that's about it...
    Help please
    579 times
    Dayton, WA
    13,187
    Go to the previous posts, read the Understanding the Side Switch link, and make sure you do not have mute enabled either on the switch, or in the multitasking bar. Mute is the most likely cause of the symptoms you are describing.
  1. Sound? I've lost my sound! Help! Please
    By Hdchiky in forum iPad Help
    Last Post: 03-13-2012, 01:34 PM
  2. Replies: 0
    Last Post: 01-01-2012, 08:07 AM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
how come the sound on my ipad isn't working
ipad isn't making sounds
ipad isn't playing sound
my ipad isn't making sound
my ipad isn't playing all sounds
my ipad isn't playing sound
my ipad sound isn't working
the sound on my ipad games isn't working
the sound on my ipad isn't working on some apps
why doesn't my ipad play sound
why isn't the sound working on my ipad
