Make my ipad think its connected to wifi??
This is a discussion on Make my ipad think its connected to wifi?? within the iPad Help forums, part of the Apple iPad Discussions category; Ive got a 64g wifi+3g jailbroke ipad 2 with a 15g data plan and want to use it to watch 4od ect, but i am ...
Results 1 to 4 of 4
    167569
    Feb 2012
    Blackpool
    Ive got a 64g wifi+3g jailbroke ipad 2 with a 15g data plan and want to use it to watch 4od ect, but i am using 3g when i need wifi connection, is there anyway i can use an app or something to make it think its on wifi? Or possibly connect to a hotspot i have made?? Any help would be appreciated thanks
    167342
    Feb 2012
    84
    You would need to fool the card into thinking its connected...no app that does that afaik
    12119
    5 times
    Aug 2010
    New York
    186
    Install 3G unrestrictor from Cydia. This does what you want. It fools apps into thinking they are running on wifi.
    One important note. If your 3G speed sucks, the apps performance will suffer.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Yep, 3G Unrestricter will do it.
    good for being able to download apps from the app store over 3G that are larger than the apps store allows over 3G.
  1. staying connected to wifi?
    By jcallaway22 in forum iPad FAQ
    Last Post: 10-06-2012, 07:50 AM
  2. Replies: 2
    Last Post: 12-07-2011, 03:58 PM
  3. Replies: 6
    Last Post: 09-09-2011, 09:35 AM
  4. Wifi connected but no Internet
    By Bangbong in forum iPad Help
    Last Post: 08-27-2011, 11:34 AM
  5. PC loses WIFI with iPad connected
    By Creedo in forum iPad Help
    Last Post: 12-19-2010, 09:04 AM
cydia trick ipad connected to wifi
how to make apps think they are on wifi
how to make ipad think its on wifi
how to make my iphone think it is on wifi when im on 3g
how to make your apps think they are on wifi
how to make your ipod think its connected to wifi but it isnt
make app think its on wifi
make ipad think youre on wifi
make your iphone think it's using wifi
trick ipad to think its on wifi
