charging issues
This is a discussion on charging issues within the iPad Help forums, part of the Apple iPad Discussions category; Has any one experience this problem. and any ideas on how I can fix this. I have plugged in my iPad into a usb 2.0 ...
Results 1 to 10 of 12
Thread: charging issues
    8644
    Jul 2010
    Toronto
    charging issues
    I have plugged in my iPad into a usb 2.0 socket and it sync's up with itunes but will not charge. Now this is the same cable and socket that I use to charge my iPhone which runs fine. I'm running Windows XP.
    any help is much appreciated.
    iPad Enthusiast!
    7236
    Jun 2010
    Washington, DC
    64
    iPad's need a High Power USB 2.0 Port to charge. See this article .... iPad: Charging the Battery
    WeRule, WeFarm & WeCity ID: Balibe
    Quote Originally Posted by Qui-Gon Jinn (Star Wars Episode 1)
    "The ablilty to speak does not make you intelligent!"
    8644
    Jul 2010
    Toronto
    being there done that. On my motherboard I have 4 usb 2.0 outlets. tried all 4 and same result
    3851
    19 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by dmanero View Post
    Maybe your not understanding.
    the ipad needs a HIGH POWER usb 2.0 port in order to charge at full speed. If your USB port and computer motherboard dont give out enough power it wont charge at full speed. It will only charge slowly while the ipad is in sleep mode.
    You can check the computer manufactures website and see if they have an updated bios or drivers that support the higher power the iPad requires. If not than you just have to charge it slowly while in sleep mode or plug it into the wall.
    iPad Enthusiast!
    7236
    Jun 2010
    Washington, DC
    64
    Did you even look at the article? It explained everything!
    Thanks Mike for spelling this out for him, it a shame it has to be done for some that don't even take the time to review the information provided to them.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    When I used to wear an olive drab uniform and got paid to be shot at, we had a saying, "When all else fails, RTFM!"
    6282
    Jun 2010
    United Kingdom
    509
    The iPad is to be charged using the supplied plug and USB cable.
    IPad 64GB Wi-Fi + 3G
    8866
    Jul 2010
    5
    Csquid
    If it helps - I was having the same trouble. My iPad would not charge from my HP laptop when I used the cable that come with the iPad. A friend of mine told me about a new USB charging cable called the Csquid. It worked great - allowing me to charge in a "green" mode or I can use it as a datasync cable. I found it at Amazon. - just search for "Csquid".
    I also found some more info about it at the website for Agreenc.
    (It won't let me post the link here, since this is my first posting...)
    8869
    Jul 2010
    Abu Dhabi
    I can solve this problem, there is one program that needs to install in your computer that make the USB to work and charging your IPad.I tried and it is working in my computer and charging my IPad at this time I am a way from my computer when I reach there I will give the name of this program it is free.
    thank,
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    I think some of you are making this much more complicated than it needs to be! Why not use the charger that came with the iPad?
  1. Solar charging
    By dbdoug in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-30-2012, 07:17 PM
  2. Charging the iPad
    By pdhughes1 in forum iPad Help
    Last Post: 09-20-2011, 03:58 PM
  3. Charging my ipad with my pc
    By clarman in forum iPad General Discussions
    Last Post: 05-27-2010, 04:42 PM
  4. Charging from computer?
    By mamiamjo in forum iPad Help
    Last Post: 04-19-2010, 04:45 PM
  5. Charging module
    By ptmark in forum iPad General Discussions
    Last Post: 04-04-2010, 03:04 PM
charge ipad from hp laptop
charge ipad with hp laptop
charging ipad from hp laptop
charging ipad with hp laptop
how to charge an ipad to a hp laptop
how to charge ipad from hp laptop
how to charge ipad on hp laptop
hp ipad charger
