A little advise from more learned than me.
This is a discussion on A little advise from more learned than me. within the iPad Help forums, part of the Apple iPad Discussions category; Although I use my iPad for 99% of computing I am finding I need to use my DH old desktop sometime. I installed drop box ...
Results 1 to 3 of 3
    iPad Junkie!
    767
    Feb 2010
    Murrells Inlet, SC
    219
    Question A little advise from more learned than me.
    Although I use my iPad for 99% of computing I am finding I need to use my DH old desktop sometime. I installed drop box and I think that will be a big help but I want to know about pages for iPad. What could I use it for. I typed a letter on the old tired desktop and it was a chore. Is there any way I can type letters and address labels on iPad and transfer to computer. I have an old HP printer hooked up to desk top and of course that won't work with ipad How much can you really print on wifi printer with iPad. I may have to break down and buy an inexspensive computer for DH. He just uses iit to play games and read comics and sports. He Is visually impaired and can't do much on computer so I would rather keep using old one he is used too and I will use iPad as much as I can. Maybe someone can make sense out of my rambling.
    Thanks,
    Grandma
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    yes you can type letters in pages and transfer them to the PC. Not so sure about typing up label.
    There really isnt any good way of printing from the iPad currently. I think apple is working to add this functionality though.
    The iPad isnt a computer/laptop replacement its something in the middle of a laptop and iPhone/iPod.
    5990
    Jun 2010
    Morgan Hill, Ca
    27
    As a test, I printed a photo from my iPad directly to my HP8100 using clip print using wifi. Worked perfectly the first time. I have no doubt I can print text. You can also download an app that runs on your computer, so your file goes to your computer and then directly to your printer.
    I'm sure there are other solutions as well with various apps. Do a search on print.
    Richard Harper
    64GB 3G
how to print from ipad with hp 8100
hp 8100 and ipad 3
hp 8100 for ipad
hp8100 ipad
ipad print hp8100
