Custom notification tones not showing in iPad 2
This is a discussion on Custom notification tones not showing in iPad 2 within the iPad Help forums, part of the Apple iPad Discussions category; Hopefully this isn't a dumb question. A forum search about custom notifications showed an unanswered question from 2010 and another thread saying you can only ...
Hopefully this isn't a dumb question. A forum search about custom notifications showed an unanswered question from 2010 and another thread saying you can only have custom ones if you jailbreak the iPAD back in May 2011. But, I found conflicting information on the web, including one article dated October 2011 stating adding custom tones was now possible. It said you could do it for the iPad, but then only talked about the iPhone.
I have a standard notification tone I use on my laptops and Droid phone. I recently received an iPad 2 as a gift and wanted the same tone since it's wired into my brain as the new email sound.
I loaded it into iTunes on my PC and did the right click --> Create AAC version to make the .m4a version. I then changed the file format to .m4r, moved it to my device in iTunes, showed the Tones directory, copy/pasted it there, and then synced.
It now shows up in the music app on my iPad, but not in the list of notification tones or ringtones as a selection for the new mail notification.
Am I missing a step? Or are the articles I'm reading wrong and you can't do it for the iPad 2?
02-05-2012 11:34 AM
Originally Posted by
Cable2001
The first thing that comes to mind is that you haven't enabled syncing of ringtones in iTunes under the device settings, but assuming you have it should be listed at the very top of the section title Ringtones on the screen where you can change the alert sound.
I use a custom tone for new mail alerts on my iPad 2 and have since I got it back in October, so it can definitely be done. I do know from personal experience if the tone is short (less than 2 seconds when I was experimenting) they won't always show up.
Well, I got it to go but I'm not sure how because I tried multiple things. I ended up pasting and adding the file to the Tones directories in both the main Library and Devices in iTunes. After multiple syncs it suddenly showed up.
- You may not post replies
- You may not edit your posts
Forum Rules
By AdamDelta in forum iPad Apps
Last Post: 02-01-2012, 10:37 AM
By wahoowad in forum iPad Help
Last Post: 01-02-2012, 08:59 AM
By iDan in forum Apple iPad News
Last Post: 06-13-2011, 12:01 PM
By Ipad Girl 3398 in forum iPad Help
Last Post: 02-09-2011, 09:53 AM
By wot_fan in forum iPad General Discussions
Last Post: 04-11-2010, 10:51 AM
alert tones for ipad2
change alert sounds ipad2
change ipad2 tones app
change notification sounds on ipad 2
change sounds on ipad 2 custom jailbreak
could you change your notification sound on ipad 2
create notification sound ipad2
custom tones for ipad
how to change the sound when notifications come up on the ipad 2
how to create notification tones for ipad
how to have notification sound on ipad2
ipad 2, mail, no notification
ipad custom mail sounds
ipad notification tones
ipad notify tone
ipad2 change email notification sound
my ipad app is not listed in notification
new mail tones ipad 2
notification ipad 2
twitter not showing notifications ipad2
