Need Help With Synching iPad, Using My Laptop
This is a discussion on Need Help With Synching iPad, Using My Laptop within the iPad Help forums, part of the Apple iPad Discussions category; I am wondering if it's possible to transfer a large (50.3 MB) text file from my laptop into an app that resides on my son's ...
I am wondering if it's possible to transfer a large (50.3 MB) text file from my laptop into an app that resides on my son's iPad. When I plug his iPad into my laptop, I get the message from iTunes to the effect that iTunes can only synch to one computer, and, if I continue, it will wipe out everything on the iPad's iTunes, replacing it with everything on my laptop's iTunes. Well, I don't want to wipe put everything on his iPad's iTunes, so I'm stuck.
All I want to do is transfer this single text file that resides on my laptop's desktop into an app on his iPad.
It wouldn't have been a problem, if my son had left his laptop with me, along with his iPad, as I could've then simply transferred the text file from my laptop into his laptop's iTunes, then just synched his laptop with his iPad. But, since he didn't leave his laptop with me, and he lives a long ways away, I'm stuck trying to see if there's a way to somehow drag/drop/transfer this text file directly from my laptop onto his iPad. Is this somehow possible, or not, without having his laptop? It seems like it should be possible, since I know his iTunes user name and password, but I don't know too much about iTunes, so maybe it's impossible.
Any help would be greatly appreciated. Any instructions need to be pretty clear (step-by-step), as I'm kinda challenged, here, when it comes to iTunes and Apple stuff.
02-01-2012 12:29 AM
You could try using DropBox, download it to your laptop and his iPad, drag the file into your Dropbox and it should appear on his iPad in the DropBox App.
iPF Elite
File Sharing shouldn't depend on whether the iPad is synced; in theory.
Give this a try.
Go into your Preferences in iTunes, the Devices tab, then check the box to prevent iPod's, etc from syncing automatically.
Now connect the iPad again, and it shouldn't insist on syncing or erasing. Even if you get a dialog, just cancel it.
Go to the File Transfer options under the Apps tab. If the app supports File Sharing you should see it in the list and be able to add your file there. File Sharing happens as soon as you add or delete files. There is not sync required, so when it is done you should be able to disconnect the iPad and find the file in the target applications.
iOS: About File Sharing
If the app does not show up in File Sharing, or this does not work for some other reason you'll need to use a wireless or internet solutions (like Gabriel suggested with DropBox).
- You may not post replies
- You may not edit your posts
Forum Rules
By ssmail in forum iPad 1 Forum
Last Post: 11-18-2011, 01:12 PM
By Ellerton in forum iPad Help
Last Post: 05-09-2011, 03:29 PM
By stevei in forum iPad Help
Last Post: 12-10-2010, 12:15 AM
By firmament in forum iPad Help
Last Post: 11-12-2010, 03:35 AM
By windycitycouple in forum iPad Help
Last Post: 06-25-2010, 10:29 PM
do i need internet to sync laptop and ipad
erase messge when syncing ipad on laptop
help laptop and ipad not synchronizing
how do i synch my laptop and my ipad?
how do i transfer files from my laptop to my ipad
how do you sync ipad with laptop
how to get internet for laptop using ipad
how to sync ipad and laptop
how to sync ipad to lap top
how to synchronise laptop with ipad
laptop not syncing ipad
my ipad could not be sync with my laptop
sync ipad 1 to laptop
sync laptop with ipad
syncing laptop to ipad for internet
transfer file from laptop to ipad
